wheel help
Discussion in '1st Gen. Tacomas (1995-2004)' started by YotaDude01, Jun 15, 2010.
  1. Jun 15, 2010 at 5:43 AM
    YotaDude01
    YotaDude01 [OP] Kentucky Boy
    KY
    01' TRD off-road
    I have a 01 trd off road taco and I'm wanting to put some good looking wheels on it. Could you all please give me some ideas of what would look good and not be god awful expensive. also I would like them to he able to fit the stock tire size if possible. Pics would be nice. Thanks guys.
  2. Jun 15, 2010 at 6:49 AM
    96er
    96er Sport Rally'er
    MA
    '96 Tacoma XCab 4x4 SR5
    As many people that have them, I still think the Mickey Thompson Baja II/ARE Baja/Procomp 8 hole wheels are timeless classics.
  3. Jun 15, 2010 at 6:56 AM
    offroadTRD
    offroadTRD Well-Known Member
    Dinwiddie County, Virginia
    2000 Tacoma V6 SR5 4x4 TRD- Fabtech
    Fabtech 3" adjustable coil-over system, Alcan 8-leaf spring pack, Fabtech 3" body lift.
    american racing type-23
  4. Jun 15, 2010 at 8:59 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I am partial to flat black wheels on Impulse Red trucks. :p One of the wheels I considered for mine were these Black Rock wheels. They are a "satin" finish and would look great and, for an alloy type, fairly inexpensive.
    These are called Type D Alloy - Series 909. I'm not sure if they are available in a 16" rim.
  5. Jun 15, 2010 at 9:17 AM
    OCTaco
    OCTaco Well-Known Member
    OC
    '16 TRD Sport DCSB
  6. Jun 15, 2010 at 9:42 AM
    Madjik_Man
    Boulder, CO
    1998 Ext Cab 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    I reeeeeeally like the looks of these.
    Apparently $100 per wheel. Not bad
  7. Jun 15, 2010 at 4:33 PM
    YotaDude01
    KY
    01' TRD off-road
    Does Chevy bolt pattern fit my truck. I heard they was the same and I was wondering if it was.
  8. Jun 15, 2010 at 4:35 PM
    mwild
    mwild I CANT SPELL SO DONT BITCH
    Vernon, NJ
    03 2500 Dodge Ram
    Cat-Back, weather techs, ipod and sisuis Old 04 Taco: 5100s At all 4 corners set at 2.5", Toyotec AAL, Gibson cat-back, Deck plate mod, 20% Tint on fronts, 10" Kicker Comp sub, Sirius radio, Bud Built Skid, Pro Comp 8069 Wheels
    I think they are the same.
    I have procomp 8069s on my truck and i love the way the look. Check my build or gallery for pics.
  9. Jun 16, 2010 at 4:26 AM
    YotaDude01
    KY
    01' TRD off-road
    how much did those cost you.. they look nice.
  10. Jun 16, 2010 at 4:29 AM
    AlexanderD
    AlexanderD Well-Known Member
    Alex
    whitby Ontario
    03' tacoma 4x4 trd step-side
    x2 8069's
  11. Jun 16, 2010 at 4:41 AM
    YotaDude01
    KY
    01' TRD off-road
    they look really good. when ordering them do i need the 6 by 5.5 bolt pattern. or what one would i need.
  12. Jun 16, 2010 at 4:46 AM
    AlexanderD
    Alex
    whitby Ontario
    Yup 6 X 5.5 is the correct pattern. I went with the 15" because they are a little cheaper and 15" tires are a little cheaper too. not to mention the less backspacing sticks them out more for a better look(imo) and wider track.
  13. Jun 16, 2010 at 5:10 AM
    YotaDude01
    KY
    01' TRD off-road
    What is the best place to order them from. Ill prolly get me a set.
  14. Jun 16, 2010 at 7:53 AM
    AlexanderD
    Alex
    whitby Ontario
  15. Jun 17, 2010 at 9:18 AM
    YotaDude01
    KY
    01' TRD off-road
    thanks man. im also looking at the mickey thompson classic 2 wheels as well.
  16. Jun 17, 2010 at 10:22 AM
    96er
    96er Sport Rally'er
    MA
    RE: backspacing. I think 4" is the standard, on a 15x8 how far out from the fenderwell will these go? What about a 3.75" backspace? Will it look like a lowrider and stick out too much?
  17. Jun 17, 2010 at 1:56 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    same bolt pattern... chevy is smaller bore size
  18. Jun 18, 2010 at 3:21 AM
    AlexanderD
    Alex
    whitby Ontario
    3.75 is what i have and the 31 10.50 r15's i have on stick out maybe an inch from the flairs. i think it looks good. see pics here.
  19. Jun 18, 2010 at 7:01 AM
    pittim
    pittim mittip backwards
    Pink slider.
    yep, both toy and chevy are 6x5.5"
    toy hub size is 108mm, chevy is...smaller.
    as far as backspacing...
    the factory wheels are 16x7 with 4.5" bs.
    if you go 16x8 with 4" bs, the outside of the tire will be 1.5" further out from the truck.
  20. Jun 18, 2010 at 7:12 AM
    AlexanderD
    Alex
    whitby Ontario
    correction: the center line of the tire will be 1.5" further away from the frame. the tire's sidewall location would also be dependent on the tire size(width).
