Wheel hop?
Discussion in 'Suspension' started by 1tacoplease2.0, May 28, 2020.
  1. May 28, 2020 at 9:03 PM
    1tacoplease2.0
    1tacoplease2.0 [OP] Well-Known Member
    RJ
    Hawaii
    2008 S4x4 Access Cab SR5 6 speed manual supercharged
    I’ve been running the 5100’s up front at the highest setting, stock UCA’s and spiertraxx wheel spacers and have always noticed (feels like) driver side wheel hop when turning and hitting bumps, hitting bumps at a higher speed or highway driving (65mph+) and drive across a highway dip or a fixed pothole.
    I notice it most when I get new tires or get them rotated and balanced and they fill my tires to the tires specs. Usually airing down to 32psi help a lot but doesn’t get rid of it completely.
    Any ideas on what it could be and a solution?
    I’ve had this problem for years and hasn’t been too bad but now that I’m ready to supercharge, I don’t want this to be an issue at all. Thanks in advance.
  2. May 29, 2020 at 8:54 AM
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    "I notice it most when I get new tires or get them rotated and balanced and they fill my tires to the tires specs. Usually airing down to 32psi helps but a lot but doesn’t get rid of it completely."
    Are those E Rated tires?
  3. May 29, 2020 at 2:25 PM
    1tacoplease2.0
    RJ
    Hawaii
    I’m on C rated KO2’s now and my previous tire was BFG rugged terrain which was like a street tire.
  4. Jun 2, 2020 at 4:55 AM
    1tacoplease2.0
    RJ
    Hawaii
    I’m going to try and get an alignment and see if that helps.
  5. Jun 2, 2020 at 5:25 AM
    Clearwater Bill
    Billy
    Largo Florida
    Wheel hop is a term normally used for rear wheels during 'launch', but it sounds like you are describing a front end situation?
    So they are filling to the max pressure number on the sidewall? Ham fisted yo-yo's. You need to do a chalk test and determine the correct pressure for your truck, and adjust to that. It may or may not be different than 32
    While you may need an alignment, it won't help what you describe.
    IF it's only on one corner as you say, I'd be looking into it being a bad shock or even binding or broken coil.
    I'd also run the proper spring for the lift you want and put the springs back on the 0 perch. Just because someone makes a product with multiple perches, allowing lift to be created with preload, doesn't mean it's a good idea.
    And keep in mind that the SC addition will likely create wheel hop in the rear you'll need to address.
  6. Jun 2, 2020 at 6:16 PM
    1tacoplease2.0
    RJ
    Hawaii
    Thanks, I am describing my front and it’s the only way I know how to explain it.
    I’ll see if I can alleviate this situation before I do an alignment.
    I’m using my stock springs and have always had this issue as soon as I lifted. I cannot no longer go to zero perch because I’m running bigger tires.
    I appreciate your input.
  7. Jun 4, 2020 at 9:37 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Possibly bump steer since it happens on potholes.
    1tacoplease2.0[OP] likes this.
  8. Jun 4, 2020 at 4:01 PM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    It’s possible to run bigger tires on the zero perch. Some trimming, CMC(if not already done), space down the bump stops and add additional caster
