Wheel Hub/ Bearing issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dlarpre, Dec 8, 2022.
  1. Dec 8, 2022 at 10:46 AM
    dlarpre
    dlarpre [OP] New Member
    Danny
    Reno, NV
    2012 Double Cab Tacoma Offroad
    I have been driving a 2012 Tacoma OR for about a year and have been putting up with what I originally thought was just wheel noise. This noise is more of a roar that builds with speed and quickly overtakes the engine noise. I have also had a bit of a steering shake that comes and goes in severity. I have rotated the tires and tried the ole shake the wheel as its in the air trick to see if the bearing had any give and it seemed solid but all of the other symptoms that I've looked into (wheel shake, roaring noise, etc..) seemed indicative of a bearing issue that I think is coming from the front. I would like to replace the front pair of hubs and bearings and I think the deal from 05Taco4x4 (https://www.tacomaworld.com/threads/wheel-bearings-hubs-press-service-4x4-6-lug-2wd.537080/) is the way I am leaning. Is there anyone out there with similar experiences or with advice that can maybe better diagnose the issue without taking it apart? I'd like to have a good idea of how much of a difference new hubs and bearings would help before I spend the money and a weekend potentially making things worse or not fixing the actual issue. All help is appreciated!
  2. Dec 8, 2022 at 10:51 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    My 09 started making a little noise at about 105k....i put chassis ears on it...it was the LF.
    So i went to toyota and bought just the bearing....we have a Big press here and i thought
    i was never going to be able to push the Hub out....it was in there
    dlarpre[OP] likes this.
  3. Dec 8, 2022 at 10:53 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Lift the front wheels off the ground, spin each wheel with one hand while holding the knuckle with the other hand. If the bearing is bad there will be roughness felt through knuckle. Like a bad Rollerskate bearing. Compare side to side. If one side is smooth and the other side is rough, the rough side is your problem
    TnShooter and dlarpre[OP] like this.
  4. Dec 8, 2022 at 12:49 PM
    Goldwrench
    Goldwrench Well-Known Member
    2010 silver 4wd access taco
    Bought used and mild lift
    My experience for what it’s worth. 2010 4wd, 100,000 miles or so. While driving, humming noise similar to tread noise from tires. Swerve momentarily to left, that particular noise went away. Swerve to right, noise still there. Having worked at an independent repair shop, and diagnosing that type of noise on other brands, the right front is going bad. Yep, no slack in wheel bearing, up or down , side to side. Rotated tire while feeling spring, knuckle, etc, no noise. But! Right side is curb side while driving streets, and there is more debris and water, snow, or ice for that wheel. Removed wheel, bearing assembly. Pulled apart bearings from hub. Yuck! And yuck again. Grease, which is white lithium from factory, was red dirt color, and sparse. Cleaned up the bearings best I could, and yep…there it was. One roller bearing scarred. Didn’t need to inspect any further. Went to dealer, purchased new bearings, seals, and bolts, for both sides. Learned long ago…one side bad, other side getting ready to go bad too. Sorry, parts knew who I was, as I said, having worked the line and ordered parts from them when needed. $$ discount, and since I’m retired, was welcome. I have a press, so, no big deal to do what I needed to do. Anyway, noise gone, barely hear the Korean tires on pavement .
    flysiu and dlarpre[OP] like this.
  5. Dec 8, 2022 at 1:05 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    It can be difficult to test the wheel bearing as you did with the calipers/brakes installed. Additionally, roaring wheel bearing noise is not always indicative of loose/worn bearings. The noise can be cause by dry bearings and/or water getting inside causing corrosion. The steering wheel shake may not be related to the wheel bearings. You may need a new needle bearing and/or CV shaft(s). I would replace the bearings first than re-evaluate the steering wheel shake.
  6. Dec 8, 2022 at 1:25 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
  7. Dec 8, 2022 at 2:13 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If you get movement with the old grab the wheel and shake method, the bearing super bad.
    These trucks don’t respond well to that method. You have to do as @b_r_o said, feel the knuckle.
  8. Dec 8, 2022 at 2:17 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Its kind of a weird trick but it works
    dlarpre[OP] and TnShooter like this.
