Wheel Info
Discussion in 'Wheels & Tires' started by wilsonpj, Jun 16, 2010.
  1. Jun 16, 2010 at 10:37 AM
    wilsonpj
    wilsonpj [OP] Well-Known Member
    Pete
    Charleston, South Carolina
    2006 DC, SB, OR
    OME 3in Lift, LR UCA's, 33in DuraTracs, All-Pro Full Skids, TRD CAI & Cat Back, 16x8 KMC Enduros
    Looking at getting some 16x8 Atx chambers or KMC Enduros with 4.5in backspacing, going on 285x75x16 tire.
    1.) What is the difference between the bolt patterns 6x5.5in and 6x139.7mm - seems the same to me?
    2.)What is the "lug nut seat style"? "Conical seat - 60 degree"
    3.)What is the Tacoma bore diameter...?
    4.) Hub centric or not....
    Basically I'm just trying to figure out the correct model to order and didn't know there were so many options. Any help would be appreciated.
  2. Jun 16, 2010 at 12:24 PM
    wilsonpj
    Pete
    2006 DC, SB, OR
  3. Nov 12, 2010 at 1:18 AM
    TacoBlitz
    TacoBlitz Well-Known Member
    Jake
    Omaha, Nebraska
    01 DoubleCab SR5 TRD, white
    Topper, Yakima Racks, Yakima Loadwarrior roof basket (lights all around) 20% window tint (all 4 doors), Spectre ProFab Air Intake System, Black grille, Rino Lined rocker panels, rear bumper and flares Suspension: New OME 881 coils and OME 5 leaf rear springs, Blilstein shocks and struts, Daystar Greasable lift shackels Extended rear brake line
    I wish I could help. I have many of the same questions as you do.
  4. Nov 12, 2010 at 1:59 AM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    - No difference: 139.7mm = 5.5 inches
    - It's how the lug nut sits on the wheel. 3 types exist, Conical being the most common. Conical is an acorn seat type, which is tapered at 60 degrees. This doesn't vary, it is a standard.
    - 106mm
    - What is your question?
  5. Nov 12, 2010 at 2:15 AM
    BrettBretterson
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    PS, I realize these are answers to old questions for the OP, but should be able to help others in the future.
