Wheel just fell off... on side of road could use advice
Discussion in '2nd Gen. Tacomas (2005-2015)' started by excorcist, Sep 17, 2017.
  1. Sep 17, 2017 at 7:05 PM
    excorcist
    excorcist [OP] Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Lugs just snapped, I'm on the side of the road jacking up truck, it is on rear passenger axle...
    I'm about 15 minute's outide of a decent size town here in nv called Fernley...
    Without having time to research, can I fix this roadside? Will O'Reilly or the like have the lug studs?
    EDIT: Was able to fix roadside using 3 studs from other axle. See post #60 for picture
  2. Sep 17, 2017 at 7:06 PM
    TacoZim
    TacoZim Well-Known Member
    Bay Area, CA
    2008 DCLB
    Bump for OP. Hope you get off the side of the road soon bud.
    excorcist[OP], EubeenHadd and RobP62 like this.
  3. Sep 17, 2017 at 7:08 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Lug nuts broke?
    Or the lug studs?
    If they all broke something else is likely wrong!
    scottalot, RobP62 and Roland79 like this.
  4. Sep 17, 2017 at 7:08 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Dude, hope you make out. Wish I could help.
  5. Sep 17, 2017 at 7:09 PM
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    There should be a shop in town that has them, if O'Reilly doesn't they'll know where to go
    excorcist[OP] and RobP62 like this.
  6. Sep 17, 2017 at 7:12 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    If you can get the drums off, rob 3 from the other side. You will need a punch to drive out the broke bolts.
    The bolts on the good side can be driven out after you put a lug nut on to protect the threads. Hit the nut with a hammer and they should pop out.
  7. Sep 17, 2017 at 7:15 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    Autozone in Fernley is open until 9. Shows stock on:
    2006 Toyota Truck Tacoma 4WD 4.0L FI DOHC 6cyl Dorman Wheel Stud, Part Number: 610-266.1 Fits Your Vehicle
    Dorman Wheel Stud
    Price: $2.49
  8. Sep 17, 2017 at 7:18 PM
    excorcist
    Reno, NV
    Studs broke... taking 3 from the other side is good advice! Luckily have 4g service so might just call an uber into town and pick some up...
  9. Sep 17, 2017 at 7:20 PM
    bubba433
    bubba433 Active Member
    SoCal
    Local shops should have some. Make a couple calls to the nearest ones to see about whether they have any in stock. It's a fairly easy repair to replace the studs. That's a pretty big red flag that they all sheared. Most common reason for it is if someone doesn't use their hands to get the lug nuts hand tight first, then going on to an impact to finish. They'll start the threads with the impact and it'll cross thread and can lead to the stud shearing if they really went at it. That's pretty crazy for them all to go. I hope you get it fixed safely and without too many shenanigans.
  10. Sep 17, 2017 at 7:33 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    I picked up a bunch from a jacks auto parts store once. I was shocked they had them in stock(and so many).
  11. Sep 17, 2017 at 7:37 PM
    excorcist
    Reno, NV
    I actually just put this entire rear end in about 2 months ago ( it was a used axle)...
    Probably just going to have it towed... only have 1 jack and its dark out now. If I was by myself I would just take care of it here but I'm with the girlfriend and 2 dogs
    scottalot and RobP62 like this.
  12. Sep 17, 2017 at 7:42 PM
    gaprider0
    gaprider0 Well-Known Member
    Greg
    eatonton. GA
    2017 TRD PRO
    Hope you can get it fixed tonight
  13. Sep 17, 2017 at 7:48 PM
    excorcist
    Reno, NV
    What else wold be wrong? I just assumed the guy that I got the axle from had over torqued the lug nuts
  14. Sep 17, 2017 at 7:48 PM
    excorcist
    Reno, NV
    Waiting on tow truck... 370$ worth it to just fix it in my garage...
    Side note, is it customary to tip tow truck drivers?
  15. Sep 17, 2017 at 7:48 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Over torqued, cross threaded, under torqued even
    Kyitty and excorcist[QUOTED][OP] like this.
  16. Sep 17, 2017 at 7:50 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Here you go! Pull the driveshaft, put it in f(ront) wheel drive
  17. Sep 17, 2017 at 7:51 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    Glad yall weren't injured​
  18. Sep 17, 2017 at 8:01 PM
    excorcist
    Reno, NV
    Tow truck I's going to be a couple hours.. got drum off, kind of confused how these studs come off without pulling apart brake assembly, any input?
  19. Sep 17, 2017 at 8:07 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    prob have to take the axle out would be my guess
  20. Sep 17, 2017 at 8:10 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    https://youtu.be/TtNb9wKG08U
    No no no.
