Wheel/Lift Combos???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoOwner4Life, Nov 25, 2016.
  1. Nov 25, 2016 at 10:42 AM
    TacoOwner4Life
    TacoOwner4Life [OP] Member
    Wyatt
    Florida
    2000 Tacoma Prerunner 2.7L
    I want to install pro comps stage 2 6 inch lift kit for a 2nd gen tacoma. Pro comp states that you can't use stock rims and that you need to have 18 inch or higher rim size. Why is this? My plan was to buy these 17 inch trd pro rims with 35s.
  2. Nov 25, 2016 at 10:49 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Because it's a shitty lift
    agunday21, RigginsTaco and idahbro like this.
  3. Nov 25, 2016 at 10:52 AM
    TacoOwner4Life
    Wyatt
    Florida
    Lmao, helpful :cheers:
  4. Nov 25, 2016 at 10:52 AM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    You asked I answered. Been talked about a million times on here.
    sr5vic likes this.
  5. Nov 25, 2016 at 11:06 AM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Most 6" lifts aren't quality. Generally the off-road community recommends 2.5 - 3" lift maximum on a Tacoma due to drive line issues, CV issues, etc. To attain 6" usually involves bracket lifts, spacers, etc. Usually frowned upon.
    It's your truck though! If you're not looking to hit Moab, rock crawl, or do serious offroad it probably won't matter. If you like the 6" lifted look go for it. As to why they want 18" wheel size? No idea. Probably just looks better with such a huge lift.
    16" and 17" are what Tacomas come with standard depending on trim level.
    agunday21 and TacoOwner4Life[OP] like this.
  6. Nov 25, 2016 at 11:07 AM
    TacoOwner4Life
    Wyatt
    Florida
    Appreciate the comment. I live in FL don't do much serious offroading just a little bit of sand and mud sometimes. Thanks for the info!
  7. Nov 25, 2016 at 11:08 AM
    TacoOwner4Life
    Wyatt
    Florida
    Plus I want to keep cv angles and differential kept at stock levels I do a lot of driving
  8. Nov 25, 2016 at 11:26 AM
    08tacobear
    08tacobear Well-Known Member
    08 taco DCSB pre runner V-6 SR5
    12v accessory plug right rear bed bin,1gallon air compressor setup in left rear bed bin, 3-window bed topper.
    Then why would you do a 6", just for looks? It is hard on your entire truck: driveline and suspension will suffer greatly Unless it's done right. Lifts that high will need new dropped carrier bearing, new UCAs and definitely new LCAs
  9. Nov 25, 2016 at 11:30 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    You a have to cut the cross memebr on your frame. 6" lofts are a lot of time and money for looking cool..you can get a much more functional lift for half the cost and, if you need it, you will get much more ground clearance on a 3" lift and 285 than 6" and 35"+ :gossip:
  10. Nov 25, 2016 at 12:00 PM
    TacoOwner4Life
    Wyatt
    Florida
    Yeah looks, doesnt a differential drop kit like for instance with a 6 inch pro comp lift keep all factory components at stock levels?
  11. Nov 25, 2016 at 12:14 PM
    08tacobear
    No. It may be close but it also depends on exactly which pro comp kit you chose.there are several variants of their 6" lift. Some come with the new spindles and cross members but I don't see any with the carrier bearing drop which may or may not be necessary. Honestly I don't know about how all that comes together. I do know other thread for anything higher than 3 recommend new lowers and uppers and several other serious mods. I would easily trust anything kyitty says!
    You will also need to make sure the place doing it, if you aren't, does front end alignments and knows their stuff. Just seems like a lot of trouble and expense for looks....but to each their own.
  12. Nov 25, 2016 at 3:28 PM
    Jmad1997
    Jmad1997 Well-Known Member
    2005 TRD sport long bed 6" fab tech lift
    It's because the lift comes with new beefier spindles and in some not all cases the tie rods get flipped to they sit on top instead of underneath so you will need a bigger rim to account for the tie rod flip and spindle.
    08tacobear likes this.
  13. Nov 25, 2016 at 3:50 PM
    ClemsonMGM
    ClemsonMGM Even Firemen Need Heroes...
    Workin the pole!
    12 Ram 2500
    You can use those rims with some wheel spacers.
    Justinlhc likes this.
  14. Nov 25, 2016 at 3:57 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    It's the offset of the factory wheels. Wheel Spacers will fix that.
    Is this a 2wd or 4wd truck?
  15. Nov 25, 2016 at 4:04 PM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
