Wheel not fitting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Shiki Shabazz, Jan 29, 2012.
  1. Jan 29, 2012 at 2:07 PM
    Shiki Shabazz
    Shiki Shabazz [OP] Well-Known Member
    Tulsa, OK
    2003 Tacoma Dbl Cab TRD
    I have researched and researched. I bought the bronze toyota trd beadlock style wheels for my 2001 sr5 4wd and the wheel has the 6 x 5.5 bolt pattern. But the wheel only goes on about a third of the way and it gets stuck. What the heck. Everything I have read states all the 6 lugs have the same pattern so why does the wheel not fit? Thanks for the help.
  2. Jan 29, 2012 at 2:10 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    did you measure the hole in the center? bolt spacing may be right but measure that center hole
  3. Jan 29, 2012 at 7:05 PM
    Shiki Shabazz
    Tulsa, OK
    If the center hole is different it can make the wheel get stuck only a third of the way on the studs?
  4. Jan 29, 2012 at 7:47 PM
    Dromlace
    Dromlace Well-Known Member
    Michael
    Montgomery, AL
    2006 Tacoma TRD Sport
    toyos are 108mm hub
    gmc/chevrolet are 78ish or 80
  5. Feb 14, 2012 at 9:50 AM
    orangedevil37
    orangedevil37 RedBull
    cincinnati ohio
    2010 Tacoma DC 4x4 SR5
    How much did you pay for your rims?
