Wheel Offset
Discussion in '3rd Gen. Tacomas (2016-2023)' started by churchie76, Aug 25, 2023.
  1. Aug 25, 2023 at 5:31 AM
    churchie76
    churchie76 [OP] Active Member
    2020 Tacoma
    I currently have a 17X7 rim with a positive four offset on a 26570R17 tire. I am thinking about changing my wheel to a 17X9 rim with a negative 6 offset. Will this be a noticable difference?
  2. Aug 25, 2023 at 5:35 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    The centerline of the wheel will move 10mm outwards and your wheel will be 2 inches wider so yes, you will stick out a little over an inch more than now on the WHEEL. Depends what tire you go with to determine the cross section and how far that will stick out. You will also be just under an inch closer to your UCA.
  3. Aug 25, 2023 at 8:54 AM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    I suggest sticking to a zero offset at the most. Zero will be about a quarter inch past on a truck with factory flares.
    I have the same size tire on 17x9 / 0 offset if you want pic’s let me know.
  4. Aug 25, 2023 at 9:31 AM
    churchie76
    2020 Tacoma
    Yeah, sure.Send pics. Thanks
