Wheel offsets with different Gen oem tacomas
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ttravisschool, Mar 11, 2023.
  1. Mar 11, 2023 at 8:27 PM
    Ttravisschool
    Ttravisschool [OP] New Member
    Travis
    04 tacoma prerunner
    I'm wondering if a 16x7 30 offset tacoma 6 lug will fit my 2004 tacoma with 16x7 15 offset.. I don't understand completely about offset other than it needs to clear the rotor etc. Hoping someone can drop some knowledge, thanks
  2. Mar 11, 2023 at 9:55 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    Plenty of knowledge out there. This is the first link Google suggested when I searched "wheel offset" https://www.tirerack.com/upgrade-garage/what-is-wheel-offset
    This thread (which is stickied in the 1st gen section) talks about wheel fitment: https://www.tacomaworld.com/threads...er-toyota-wheels-on-my-1st-gen-thread.563416/
    The thread talks in terms of backspacing instead of offset, but the principles are the same. The two measurements are closely related--backspacing measures from the inside of the rim to the mounting surface while offset measures from the centerline to the mounting surface. You can convert between them as long as you know the width of the rim.
  3. Mar 11, 2023 at 11:14 PM
    xcmtb83
    xcmtb83 Well-Known Member
    Iowa
    Your factory 15mm offset wheels have a greater track width than a 30mm offset would have. In other words, the outer edge of your tire is 15mm nearer the center of the vehicle. If you have fender flares this goofy look is exasperated. This is a major downfall of putting newer Tacoma wheels on our 1st gens.
