wheel problems help please
Discussion in 'Wheels & Tires' started by jacswanthebarber, Jan 1, 2016.
  1. Jan 1, 2016 at 2:33 PM
    jacswanthebarber
    jacswanthebarber [OP] Member
    jacswan
    miami, fl
    trd offroad
    Hi, I got a set of jegs baja 8 wheels for my tacoma and some spacers but for some reason when I'm going from 50-65mph it shakes like crazy.I got them balanced 4 times and still nothing they told me that steel wheels are always going to shake, is there anyway I could fix that?
  2. Jan 1, 2016 at 2:42 PM
    JDM
    JDM Well-Known Member
    Jimmy
    CO
    2009 DCSB TRD OR S/C
    TRD supercharger, TRD exhaust, skids, sliders
    That is a ridiculous statement from a tire shop/garage. Of course steel wheels can be balanced and not shake.
    First thought is to find a different (and competent) shop. It may be good to find someone who can road force balance.
    Don't settle for your current situation.
    RedRed likes this.
  3. Jan 1, 2016 at 2:44 PM
    jacswanthebarber
    jacswan
    miami, fl
    trd offroad
    I went to 4 different shops the last one told me that. Should I get different spacers?
  4. Jan 1, 2016 at 2:49 PM
    JDM
    Jimmy
    CO
    Good grief. Well... in that case, is there any chance the wheels can be installed without the spacers for an on-road test? Or, have a buddy who has the same width spacers which are known to be good and swap them on?
    What I'm struggling with is that none of the shops could point their finger at an exact problem.
    Are the tires known "good" tires?
  5. Jan 1, 2016 at 2:51 PM
    JDM
    Jimmy
    CO
    Did any of those shops do a road force balancing? That's different than spin balancing and will help identify a bad tire or out of round wheel.
  6. Jan 1, 2016 at 2:54 PM
    jacswanthebarber
    jacswan
    miami, fl
    trd offroad
    I had them on the stock trd off road wheels toyota came with good tires. Can it be the spacers central hubs is not right?
  7. Jan 1, 2016 at 4:21 PM
    JDM
    Jimmy
    CO
    I would guess if a spacer isn't sitting exactly flat (or maybe was not manufactured properly) then it would cause this. Ensuring there isn't any debris, rust flakes, corrosion, etc. on the surface of the wheel flange and around the lip of the hub, and ensuring that each spacer fits properly is a must. A good wire brushing would take care of that.
    So, no chance of the wheels and tires fitting without the spacers for a test drive? If you can, it'll help narrow down the source of the problem.
  8. Jan 1, 2016 at 4:33 PM
    jacswanthebarber
    jacswan
    miami, fl
    trd offroad
    Iam going to check them out good thankyou
  9. Jan 1, 2016 at 8:47 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Im no expert on spacer design but I think you need to make sure they are hub centric and not lug centric.
  10. Jan 1, 2016 at 8:51 PM
    medic2230
    Murph
    Bama! Roll Tide
    ^^^This.
    Lug centric wheels can cause that problem. The spacers need to be hub centric also.
  11. Jan 2, 2016 at 6:13 AM
    jacswanthebarber
    jacswan
    miami, fl
    trd offroad
    Thanks
  12. Jan 2, 2016 at 6:13 AM
    jacswanthebarber
    jacswan
    miami, fl
    trd offroad
    Thanks
  13. Jan 2, 2016 at 6:13 AM
    jacswanthebarber
    jacswan
    miami, fl
    trd offroad
    Thanks
