wheel question.
Discussion in 'Wheels & Tires' started by TacomaPrime, Jul 6, 2011.
  1. Jul 6, 2011 at 9:01 AM
    TacomaPrime
    TacomaPrime [OP] Cybertronian Tacoma
    Gregory
    Illinois
    14 TRD sport 4x4 Barcelona Red
    Weathertech front floor liners, window vent visors. Custom bedside decals. OEM bed mat, tonneau covrew. Added D rings to bed.
    What offset/backspacing range should I look at for just wanting to be stock.
    I have the 265/70/16 tires and will be replacing them, but also getting some winter wheels/tires. I don't want my wheels/tires being too much closer to cause rubbing, or sticking way far out.
    Thanks.
    If I get everything the same but with 4.75" backspacing will I rub, and what offset do I want?
    Aos, I assume I can use trd sport wheels as well. I plan on getting new wheels for winter wheels/tires.
  2. Jul 6, 2011 at 5:39 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Stock backspacing is 5.5" . Offset is calculated from backspacing and width. Don't worry about offset, just backspacing.
  3. Jul 6, 2011 at 6:07 PM
    TacomaPrime
    Gregory
    Illinois
    so if i get a rim that the backspacing is 4.5", then the wheel will stick out farther away from the truck by an inch. Where if the backspacing is 6.5" is will sit closer to the truck by an inch? Will the 4.5" BS one cause rubbing with stock tire sizes?
  4. Jul 6, 2011 at 6:11 PM
    TexasTacoma37
    The 4.5" rim will stick out and inch more only if it is the same width. If it is also an inch wider, it will stick out an additional inch.
    6.5 would be in another inch and be too close to the uca. 4.5" will be fine with stock tire sizes.
