Wheel Question
Discussion in 'Wheels & Tires' started by drmcstford, Nov 25, 2013.
  1. Nov 25, 2013 at 6:15 PM
    drmcstford
    drmcstford [OP] The Sauce Boss
    David
    Glendora, CA
    14 Prerunner TRD OR
    Hey guys sorry If this has been answered before I tried searching but no Luck ! My question is would I still be able to use my stock BF Goodrichs A/T (i think their bad ass for stock) with these with no problem? And If i do, do i have to transfer the TMPS system to the new wheels and will they go in easily with no problems? I'm going to upgrade tires later on ! Also some guy asked a question on the bottom of the page and the sells man said these dont fit????? http://www.4wheelparts.com/Wheels/Series-5001-16x8-with-6-on-5-5-Bolt-Pattern-Satin-Black.aspx?t_c=11&t_s=210&t_pt=100073&t_pn=PXA5001-6883#
  2. Nov 25, 2013 at 10:10 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Those wheels should fit your truck just fine. If you're stock wheels are alloy, the TPMS will transfer over without a problem. You should swap them over so you don't end up with the annoying low tire pressure light. Lastly, your stock tires should work so you're good to go. Good luck!
  3. Nov 26, 2013 at 6:26 PM
    drmcstford
    David
    Glendora, CA
    14 Prerunner TRD OR
    Awesome :D Appreciate it! One more ? What does backspacing mean? I'm set either on thoose or some other one from Americas tire my buddy works their and gets 30% off LOL
  4. Nov 26, 2013 at 6:29 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    Google is your best friend;). A quick search will tell you everything you need to know.
  5. Dec 3, 2013 at 2:28 PM
    drmcstford
    David
    Glendora, CA
    14 Prerunner TRD OR
    So Im actually going to end up going with these http://inlandempire.craigslist.org/pts/416984004.html their 16x8 6-5.5 and 4.5 backspacing which i should be good. Does the TMPS system just get switched over to these when i take it to discount tire??
  6. Dec 3, 2013 at 3:47 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    If your stock wheels are alloy then, yes, the sensors will transfer right over. Just tell DT that you want to swap them over. Good luck!
  7. Dec 3, 2013 at 4:02 PM
    drmcstford
    David
    Glendora, CA
    14 Prerunner TRD OR
    SCSPerformance thanks so much man!!! Seriously appreciate it !:headbang: and yea the alloys are what i have ! hopefully its smooth sailin !
  8. Dec 3, 2013 at 4:05 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    No problem. I'm glad I could help out. Negotiate a little on that pricing;). They've been sitting around for a long time so I'm sure you could get a better deal on them.
  9. Dec 3, 2013 at 4:23 PM
    drmcstford
    David
    Glendora, CA
    14 Prerunner TRD OR
    WAYYY ahead of you no way i was gonna pay retail on craigslist! negotiated him down to 400 :cool:
