Wheel question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ftagolfer, Jan 19, 2018.
  1. Jan 19, 2018 at 4:21 PM
    ftagolfer
    ftagolfer [OP] Member
    Jay
    2017 White TRD Sport Dbl Cab SB V6
    I have been reading threads on here now for a few months, and after all the thoughts and beliefs on lifts, I have decided to go with the Bilstein 5100 lift kit from Headstrong for my lift. However, I also want to replace my wheels with an aftermarket wheel, and I just needed to know if I might have any rubbing problems with the wheels I want. I know I will not have any rubbing issues on the suspension, just wondering about the outside rubbing on fender wells when at full turn. I want to have a more aggressive, wider stance look. I want to get a 17" wheel, 9 inches wide, -12 offset, and 4.5 inch backspacing. I am going to put 265/70r17 tires on these wheels. I am just wondering if anyone has a similar setup, and if there is any rubbing? Thanks.
  2. Jan 19, 2018 at 4:25 PM
    cmbondo
    cmbondo Well-Known Member
    San Diego CA
    2021 Cement DCSB TRD Offroad
    FOX 2.5 DSC and some other stuff too.
    Just be aware that most tires in 265 are not recommended by the manufacturer for a 9 inch wheel. I have 9 inch wide wheels too. In hind sight I wish I would have gotten a 17x8 or 8.5 for more tire options.
  3. Jan 19, 2018 at 4:29 PM
    ftagolfer
    Jay
    Yeah, the tires I want and Goodyear Duratracs, and they do fit a 9" wheel. I just want to know if the outside of the tire will rub on fender well. The tire is gonna be sticking out about 2 1/4 inches farther than stock. What offset, or backspacing are your wheels?
  4. Jan 19, 2018 at 4:32 PM
    cmbondo
    San Diego CA
    I have 17x9 with 1mm offset which is a 5 inch backspace. I initially lifted 1.75 inches and no rubbing. But I'm a 2nd gen so there are some diffrences.
  5. Jan 19, 2018 at 4:41 PM
    ftagolfer
    Jay
    So my setup would be sticking out about 1/2 inch farther than yours. How close would that put you to rubbing?
  6. Jan 19, 2018 at 4:44 PM
    cmbondo
    San Diego CA
    Hard to say but I think I would be clear. I'm lifted about 2 or 2.25 now. The 3rd gen have more clearance to start with so I think a lot will depend on how high you lift.
  7. Jan 19, 2018 at 4:47 PM
    ftagolfer
    Jay
    The lift I'm looking at should give me about 2 1/2 inches.
  8. Jan 19, 2018 at 4:49 PM
    cmbondo
    San Diego CA
    I think you'll be fine.
