Wheel Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Devilfan, Jul 15, 2024.
  1. Jul 15, 2024 at 4:22 PM
    Devilfan
    Devilfan [OP] Well-Known Member
    Does anyone know what the weight of wheel 75154 is? These are from the 4Runners. I can't seem to find a definitive answer.
  2. Jul 15, 2024 at 10:38 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Google gets me this:
    Sent by Copilot:
    The 17" x 7.5" Toyota 4Runner Factory OEM Wheel Rim 75154 weighs approximately 34.00 lbs1. This wheel came standard on the Toyota 4Runner Trail and Trail Premium for the years 2014 to 2016, and later became the standard wheel for the 4Runner TRD Off-Road and TRD Off-Road Premium from 2017 to 20242. It’s a 7-spoke design with a machined finish and black accents. Please note that this is a take-off wheel, so it may have cosmetic imperfections but has never been driven on.
  3. Jul 16, 2024 at 4:18 PM
    Devilfan
    Thanks. I didn't think they were that heavy.
