Wheel Removal Trouble
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tylerg3, Mar 28, 2014.
  1. Mar 28, 2014 at 1:13 PM
    Tylerg3
    Tylerg3 [OP] Member
    Tyler
    Alabama
    04 Tacoma PreRunner SR5
    I decided to take the wheels off and Plasti-dip the rims black. The rear wheels came off fine after jacking it up, but when I jacked up the front and removed the lugs, the wheels wouldn't budge. Has anyone else had this problem?
  2. Mar 28, 2014 at 1:21 PM
    03DBLCABTACO
    03DBLCABTACO Well-Known Member
    Dan
    Tomball TX
    Cavalry Blue 2019 TRD OFF-ROAD 4X4
    Put lugs on loosely and make sure the truck is securely supported and hit or kick the inside of tire. It will come loose. It's just probably corroded to the hub
  3. Mar 28, 2014 at 1:22 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    It happens to me sometimes. Wheel gets a little sticky, I guess. Just have to kick the tire and break it loose.
  4. Mar 28, 2014 at 1:24 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    sometimes they require more force than a kick.
    Ive had to loosen them a turn or two and drop the jack slowly so the weight of the truck breaks them free.
    if you put anti seize on the spots that seize before putting the wheel back on it will be easier to remove next time.
  5. Mar 28, 2014 at 1:48 PM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    Kick it with your heel on one side. Not to hard the first time. Kick harder second time. I guess the plasti-dip will help that also.
  6. Mar 28, 2014 at 1:58 PM
    Dj318
    Dj318 Well-Known Member
    Dylan
    Concord, NC
    02 Tacoma
    bilstein 5100, wheelers AAL, Trail gear bumper, SOS sliders, RAT skids, 35" Mtr/k
    I always just tap on it with a hammer and rotate as i go, works every time!
  7. Mar 28, 2014 at 2:12 PM
    Pakrat
    Pakrat Well-Known Member
    Brian
    Washington,State Columbia gorge
    02 tacoma xtracab 4x4 stock
    Front dome light added,light reminder added,door chime mod, added 2nd gen 4runner headrests,grey wire mod, 2lo mod, more later.
    Something else you do is take a wheel and tire that did come off, and roll it against the one that is stuck on I've seen it done at a tire shop and it works. I also agree putting never seize on the threads and the sleeve on the end of the lug nut.
  8. Mar 28, 2014 at 2:14 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Yes it happens, my dad had that problem real bad and I was tired of getting the call saying "hey come fix this piece of shit" so I gut axle grease on the part of the rim that used to get stuck, no more problems now.
  9. Mar 28, 2014 at 2:17 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You need some of this:
