Wheel Rub - Front Passenger Side
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DocCisco, Feb 24, 2011.
  1. Feb 24, 2011 at 3:00 PM
    DocCisco
    DocCisco [OP] Well-Known Member
    David
    Utah County, UT
    LB TRD Sport 4x4
    I just put on some new 265/70/17s on stock suspension and have rub on the front passenger side. There was a small piece of the mudguard that was rubbing that I just cut.
    That opened up to what seems like a hollow behind the wheel well. Does anyone know if this is something I need to cover back up (or have steps they did before)?
    The pictures don't show the opening, but at least gives you an idea of what I'm describing.
    Any input is welcome.
  2. Feb 24, 2011 at 4:54 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    it looks like you have not cut your mud flaps
    and it appears that you may have gone over something
    and twisted your mud flap .
    I would remove the wheel, and then remove the mudflap
    and see if any metal may have got bent behind the mud flap.
    may have to pound it back in so mud flap sits correctly.
    to trim mud flaps :
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/51353-easy-mudflap-trim.html
  3. Feb 24, 2011 at 4:55 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    very simple solution...cut. or you can get difficult and go get an alignment and tell them to add caster.
  4. Feb 24, 2011 at 6:25 PM
    DocCisco
    David
    Utah County, UT
    LB TRD Sport 4x4
    thx for the flaps thread. i'll be pulling the wheel this weekend to see what's going on.
  5. Feb 24, 2011 at 6:33 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    That bump in the flap is to cover the end of the fender flair, just plastic which can be trimmed without hurting anything and water will just go thru the hole and drain out the bottom
  6. Feb 24, 2011 at 10:11 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Congratuations, you next project might be billy 5100s at the .85" setting.:D
  7. Feb 25, 2011 at 2:14 PM
    DocCisco
    David
    Utah County, UT
    LB TRD Sport 4x4
    This is re-assuring, I've looked around and it does just look like it's something I can easily patch with some foam and rubber sealant.
    lol, I so have to pace myself now. dropped $$ on wheels, tires and a long list of goodies. just glad i have a separate acct that my wife doesn't get to see.;)
