WHEEL SENSORS
Discussion in '4 Cylinder' started by 2012TacomaYNWA, Mar 8, 2012.
  1. Mar 8, 2012 at 4:52 AM
    2012TacomaYNWA
    2012TacomaYNWA [OP] Member
    Andrew
    Pittsburgh, PA
    2012 Toyota Tacoma 4 Cyl
    Bed Cover
    Been looking to change my stock 2012 reg cab tacos wheels to some aftermarket ones. I found the wheels at a reasonable price but my tire place is telling me i have to change the sensors as well. I contacted the Toyota dealership and they told me 125 bucks per sensor!! I was wondering if anyone knows where i could get these for cheaper online...
  2. Mar 8, 2012 at 6:03 AM
    FL Forester
    FL Forester Well-Known Member
    Tallahassee, FL
    2014 MGM Double Cab
    2016 TRD Suspension upgrade, 1st gen TRD Wheels, 265/75/16 Cooper RTX
  3. Mar 8, 2012 at 8:33 AM
    rodney
    rodney Well-Known Member
    '15 silva sky AC SR5 V6 4x4- Last of the 2nd gen...
    245/75-16 Duratracs & WeatherTech rain deflectors- This one is staying stock...
    do you have aliminum or steel wheels on the truck now?
  4. Mar 8, 2012 at 8:36 AM
    billv408
    billv408 Member
    bill
    san jose, ca
    12 Prerunner SR5
    Debadge, remove mud flaps, smittybilt nerf steps black, Magnaflow 16625 cat back, Black Pro Comp 7089 17x8 Rims, Nitto terra grappler 265/65/17 tires, fumoto/quick valve
    i just got new alloy wheels at 4wheel parts and they moved the sensors over from the stock steel wheels. installer said it's easy.
  5. Mar 8, 2012 at 8:45 AM
    2012TacomaYNWA
    Andrew
    Pittsburgh, PA
    Bed Cover
    i believe they are aluminum
  6. Mar 8, 2012 at 11:24 AM
    rodney
    if you have alum wheels now, and are putting alum wheels on the truck, you will be ok. simple remove and replace the sensors.
    i replaced my oem steel wheels with alum wheels, and the sensors id not fit. oem sensors from steel wheels have 40 degree heads, whereas oem sensors from alloy wheels have 20 degree heads.
    so, i made a pressure vessel. problem solved.
  7. Mar 8, 2012 at 11:30 AM
    Taqoma
    Taqoma Well-Known Member
    Brennan
    Los Angeles
    2011 TRD Off-Road
    TRD Supercharger, TRD CAI, Camburg LT, Fox 2.5x8 coilovers, Fox 2.0 bumps, Deaver e30 leafs, Fox 3.0x18 triples, Avid sliders, Yaesu 2900R, Pro Comp 7089 16x8, DDM 55w HID Hella 500FF, DDM 35w HID headlights, Magnaflow 11255 muffler, PLX DM-100 OBDII, Autometer Ultra-Lite II Boost gauge, Flex Pod gauge mount, LSK tube bumper, McNeil fenders, Fiberwerx bedsides, 285/75/16 Toyo MT's
    I just recently put new wheels on my 2011 and did not have to get new sensors. They just unscrew them and put them on the new wheels, should be no extra charge.
    But I'm sure what the others are saying about going from steel wheels to alloy is true..
  8. Mar 8, 2012 at 11:33 AM
    Toyoda Tacoma
    Toyoda Tacoma Do or Do not there is no try.
    TRD Double cab, Long box
    Roof Rack, Step Bars, Hood deflector 265/70/17 Goodyear DuraTracs
    Just another sale gimmick to buy new sensors when not needed.
  9. Mar 8, 2012 at 4:31 PM
    graduate
    graduate Member
    Western NY
    2011 SR5
    Take the ones out of your existing rims and put them all in the spare. Pressure them up and problem solved. Put regular valve stems in new rim.
  10. Mar 10, 2012 at 12:19 PM
    billv408
    billv408 Member
    bill
    san jose, ca
    12 Prerunner SR5
    the installer at 4wheel parts took my sensors from the stock 16 inch steel wheels and put them in my new 17 inch alloy wheels. he said they do it all the time no need to buy new sensors and spend more $$$ getting them initialized by dealer.
  11. Mar 13, 2012 at 11:31 PM
    PR45
    PR45 Well-Known Member
    Los Angeles
    PreRunner SR5 4cyl
    I used the sensors from the steel wheels in the TRD 17" alloy wheels. I turned them 180 degrees. Of course, if I do have a flat, they will be broken.
    And, they have to be dropped into the tire to remove the tire. To mount the tire, I dropped them into the tire with a wire through the hole. I seated the beads with a blowgun on the air line. Then, pulled them up with the wire and the airpressure helped hold them while I fumbled with the nut. Working fine for a year+.
  12. Mar 14, 2012 at 1:46 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    I went from steel wheels to aluminum raceline wheels and was able to use the same sensors. It all depends whether the new wheels need angled or straight sensors
