Wheel shake after shock adjustment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ToyoTaco06, May 27, 2014.
  1. May 27, 2014 at 8:59 AM
    ToyoTaco06
    ToyoTaco06 [OP] Active Member
    BC
    06 Tacoma SR5 Short box
    6" Lift, 35's
    Hello, I have a 06 dc shortbox with 6" lift. Camrock Uca's. Bilstein 5100 adjustable front shocks. The shocks were set at lowest with alignment and all good. Last night i pulled out the shocks and moved the ring up to the first notch, 0.75 i believe. Put everything back in and now i have a wheel shake that seems to come from pass side front tire that starts at about 80kms/hr. Im thinking maybe the toe might be out a bit now but not positive. Just looking for other opinions. Thanks
  2. May 27, 2014 at 9:10 AM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    Anytime to change the setting on the shocks it'll throw the alignment off. You'll likely need an adjustment to get rid of the shake.
  3. May 27, 2014 at 9:11 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Toe could be slightly off (these trucks have some bump steer) but shouldn't cause much shaking. So you are effectively at 6.75" lift now? Maybe the CV angles are not happy.
    Could also be something not tightened correctly when you pulled and reinstalled the shocks. Is there any play in the steering tie rods? Are the LCA bolts to the frame tight?
  4. May 27, 2014 at 9:25 AM
    ToyoTaco06
    BC
    6" Lift, 35's
    Ive done all the work myself minus alignments and everything has been replaced and yes everything is tight. I will rotate tires and take it in for an alignment. Angles are all still good too. Thanks for the input its much appreciated
