wheel shakes over bumps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mako86, Jun 9, 2011.
  1. Jun 9, 2011 at 3:58 PM
    mako86
    mako86 [OP] Member
    Nova Scotia
    09 trd sport 4x4 dclb
    I just picked up a 09 dc lb trd 4x4. The truck is either lifted or leveled not sure which. When driving over rough roads or hitting a bump the steering wheel shakes. Is this normal or is it a alignment or suspension issue.
  2. Jun 9, 2011 at 3:59 PM
    racerxtaco
    racerxtaco Well-Known Member
    Joey
    virginia
    01 xtra-cab 4X4 w/cap
    its most likely the steering shaft union. doa search on it and i also think there is a tsb for this issue as well.
  3. Jun 9, 2011 at 4:00 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
    Sounds like your caster is off. If you have a lift, you may want to get aftermarket UCAs to correct it
  4. Jun 9, 2011 at 4:02 PM
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    Mine does the same thing and it's a new '11 with no lift yet.
    Almost like there is a tiny bit of free play in the steering, but I only notice it over a bump.
  5. Jun 9, 2011 at 4:23 PM
    mako86
    mako86 [OP] Member
    Nova Scotia
    Here's a few pics
  6. Jun 9, 2011 at 4:37 PM
    MJonaGS32
    MJ
    SF Bay Area (East)
    looks like you have a spacer lift to level out the rear rake
  7. Jun 9, 2011 at 4:40 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    by this image your alignment looks to be off camber wise.
  8. Jun 9, 2011 at 4:41 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Yep spacer lift ditch that crap and buy some new shocks and coils and it should ride better.
  9. Jun 9, 2011 at 4:45 PM
    mako86
    mako86 [OP] Member
    Nova Scotia
    I did notice the camber being off. Can that be fixed with an alignment?
  10. Jun 9, 2011 at 11:50 PM
    MJonaGS32
    MJ
    SF Bay Area (East)
    I would honestly take it off and either run stock or upgrade and do it right. By the looks of your stance, your tires could lose a lot of tread life, fast.
  11. Jun 10, 2011 at 2:52 AM
    mako86
    mako86 [OP] Member
    Nova Scotia
    I think I'm going to lose the spacers and go with 5100's.
  12. Jun 10, 2011 at 11:27 AM
    Tarheelz2350
    Tarheelz2350 Well-Known Member
    Jon
    Dallas, NC
    10 MGM 4x4 TRD O/R DC
    Bilstein 5100's F/R, Tin Snip mud flap mod, Partial Debadge, Rear Diff Breather Mod, Rear Spring TSB, 265/75/16 Cooper Discoverer AT3's, Devil Horn's courtesy of Andres
    Do it you'll love it. I just put my mine on Tuesday, this week. Couldn't be happier. Check out DownSouth Motorsports if you do. They had the best prices that I could find plus they give a discount to TW members.
  13. Jun 10, 2011 at 4:03 PM
    MJonaGS32
    MJ
    SF Bay Area (East)
    good move. anything but the spacers
