Wheel shaking after new tires???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Przemekmsu, May 7, 2010.
  1. May 7, 2010 at 7:01 PM
    Przemekmsu
    Przemekmsu [OP] Well-Known Member
    Przemek
    South Jersey
    2006 Toyota Tacoma, SR5 V6, 4x4 TRD Off Road
    K&N Air Filter, WickedFlow Exhaust muffler
    So, I finally got some new tires put on (BFG's All-Terrain). Now I have noticed when I am traveling at speeds of 50-55mph my steering wheel is shaking. My question is??? Is it bad wheel balancing job or alignment issues????? Thanks in advance for your help.
  2. May 7, 2010 at 7:24 PM
    AZM9
    AZM9 Well-Known Member
    Jay
    Chandler, AZ
    2009 Prerunner TRD Sport
    ARE tonneau cover, Redline hood struts, Leaf TSB, and Trans TSB, Satoshi grille.
    I am just about ready for new tires and I already have alignments figured in my quotes. But balancing is probably the culprit.
  3. May 7, 2010 at 7:27 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    sounds like they arent balanced right.
  4. May 7, 2010 at 7:40 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    x2. With just new tires it shouldn't change the alignment unless they are using fork lifts or something to put the tires on.
  5. May 7, 2010 at 7:50 PM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    I had a similar issue. Check to make sure the sticky weights on the inside of the rim havent fallen off.
  6. May 7, 2010 at 8:16 PM
    Przemekmsu
    Przemek
    South Jersey
    Thanks to all, seems like i have to get them balanced again.
  7. May 7, 2010 at 8:23 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
    dude im having the same issue right now. Ive been trying to balance my BFG ATs for a week and cant get them to balance. The rep at Americas Tire told me 2 of my wheel are bent and that why they cant balance so I ordered two more but Im wondering if I should cancel the order. Im worried that the rims wont fix the problem, and thats the whole reason I bought them. Keep me posted on your end, curious to see what you get.
    http://www.tacomaworld.com/forum/wheels-tires/90623-issues-wheel-balancing.html
  8. May 8, 2010 at 3:00 AM
    VTDave
    VTDave Well-Known Member
    Vermont, USA
    05 Access Cab 4x4 Base 5sp Man, 16 DCSB 4x4 Sport 6sp Man
    If there was no shake before the new tires and now there's a shake, guess what? The problem has to do with the tires.
    Ask the original tire shop to road force balance the tires/wheels. If that doesn't work, take it to another shop and have them do the same.
    The Hunter road force balance instruments are AWESOME and do their job well. Some shops don't test their calibration often enough, and some have techs who don't know how to use the instrument properly, so that's why having it done at a 2nd shop sometimes solves the problem.
  9. May 8, 2010 at 2:57 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    Bad balancing. BFG AT's are a pain in the ass to balance the first time around.
  10. May 9, 2010 at 2:27 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    If the rebalancing doesn't work, try doing the chalk line on the tires for adjusting the PSI.
    EX - Draw a line across the width of the tire.
    drive a short distance
    see how the line has worn
    if more of the center is worn, too much air pressure
    if more of the edges are worn, too little air pressure.
    But after each air pressure adjustment, then take it on the highway
    and see if the different PSI settings effect the steering shaking.
