Wheel Size with Offset Help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by guyver03x, Oct 28, 2022.
  1. Oct 28, 2022 at 8:42 PM
    guyver03x
    guyver03x [OP] New Member
    Aex
    2021 Army Green Tacoma TRD 4x4 Sport
    Need help. I got 17” Fuel wheel with -12 offset. My problem is that I want to know what size tire I can put on my Taco that won’t rub and don’t want to cut. I have stock suspension. Not sure if 275/70R17 is too big. Help really appreciated.
    baltimorebirds2 likes this.
  2. Oct 28, 2022 at 8:45 PM
    mtip
    mtip Go Outside & Play!!!
    South Louisiana
    18 TRD Sport 6MT 00 Tundra 5MT
  3. Oct 28, 2022 at 8:52 PM
    PinStripes
    PinStripes Well-Known Member
    Oregon
    2018 Cement OR DCLB
    I recently responded to a very related question. Here is the thread:
    https://www.tacomaworld.com/threads/265-70-r17-12-offset-rub.776704/
    Many many more theads can be found at using the search function. This is a very common question.
    In short the -12 offset will make you rub with just about anything over stock size. How much and what you have to do is the 'art'
  4. Oct 28, 2022 at 8:53 PM
    baltimorebirds2
    baltimorebirds2 tacomama
    Brooks
    Maryland, United States
    2018 MGM Tacoma TRD Sport DCSB 4x4
    TRD Pro 17” Wheels, Toyo Open Country AT3 33s” (255/80/R17), Hooke Road Offroad Roof Rack, LEDs (Low Beams, High Beams, Fog Lights, Interior Lights, Reverse Lights, License Plate Lights), Diode Dynamics SS3 Sport Fog Lights (Yellow), Sequential Turn Signals, OME Nitrocharger Plus, OME 4004's & HS 0.5 Spacer for 3" Lift, JBA UCA, Icon RXT Option 2 Leaf Springs 2.25" Lift, Yukon Clamshell Bushing, Alpine ILX W-650 Stereo, Infinity Primus 6004a Amplifier (140w*2), Sound Ordnance M75-4 Amplifier (75w*4), Infinity Kappa 693C Component 6x9 Speakers, Infinity Kappa 63XF 6.5 Speakers, TRD Shift Knob, Black Emblem Overlays, TRD Grille Badge, OEM Door Sill Protectors, Driver’s Seat Jackers, Pop and Lock Power Tailgate Lock, AJT Designs start button and trim, 4x4 knob, shifter trim, and cupholder trim, MESO Customs Vent Rings and Door Handle Covers, Gasshole, Drop Stops, AC Drain Mod, Bed Lights, Rough Country Roll Up Tonneau Cover, Window Tint, KDMAX Tune
    Welcome to TW! I'm gonna assume you're running stock suspension. In that case, most people on here will say you can run a 265/70/r17 with no rub at all. I can attest to that as well, because before I got my 33" toyos, I had some sort of cooper highway tire in 265/70/r17 and they worked fine. No rubbing whatsoever. Those were on the stock sport wheels at I think ~+30mm offset or something? You mentioned you had -12mm fuels, but I don't think that's enough to make that particular size rub. Other's will probably chime in as well.
    If you're planning on doing some suspension upgrades, you should consider the 255/80/r17, it's a pretty good size, albeit a teeny bit skinnier, but I love the look. They're also true 33" compared to your 285/70/r17's. Oh, and Toyo for the win, you won't regret it!
  5. Oct 28, 2022 at 9:06 PM
    TwinTaco31719
    TwinTaco31719 Well-Known Member
    Eric
    Glenbrook, NV
    2023 Lunar Rock LB Sport
    I didn’t rub on 265/75/16 with 0 offset but don’t sure on -12. I’m thinking you maybe have to stick with 265/70/17 OR go with skinnies
