Wheel size ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sully1981, Jan 4, 2010.
  1. Jan 4, 2010 at 10:36 PM
    sully1981
    sully1981 [OP] Well-Known Member
    Costa Mesa, CA
    05 SPORT 4x4
    Solo XLT 19" 4WD Kit and 4-Link w/32" cycled, Caged, 41 gallon fuel cell, 2.5 bypass and coil-overs up front, 3.0 bypass and 2.5 coil-over in rear, PCI radio w/intercom and 5 headsets, 50" KC Gravity LED, 20" GG-lighting LED bar, Method Hole Wheels, Currie 9", URD CAI, 37x12.5x17 BAJA T/A, PRP Seats, Glassworks 6.5" front, Fiberwerx Bedsides.
    I have the camburg mid travel kit and fiberglass fenders but still running stock rims with spacers so i can run my 285/70/17 nittos.
    first question is on an 05 sport 4x4 and i limited to a 17 because of calipers or will a 16 work? 2nd question - what rim size do i need so i don't have to have the spyder spacers on the front anymore. I am looking to buy some rims but just want to know what size to get so i can run 33's or 285's without them rubbing as mine still do just a tiny bit on the frame when i am at almost a full turn and bad part is its mostly when i am turning in my driveway so it happens everyday.
    thanks for the help!!!
  2. Jan 4, 2010 at 10:40 PM
    lilredenfield03
    lilredenfield03 Active Member
    Sylvania, GA
    Jensen VM9423, 10" Kicker CVTs, Hifonics amp
    a 16" wheel will work. I have the trd fj wheels which are 16" with 4.5 backspacing wrapped with 285/75/16 KM2s and everything clears with minor trimming.
  3. Jan 11, 2010 at 3:54 PM
    sully1981
    Costa Mesa, CA
    05 SPORT 4x4
    what kind of trimming? On the frame rail? Thats the only place i am rubbing right now but i still have the stock 17's
  4. Jan 11, 2010 at 3:56 PM
    sully1981
    Costa Mesa, CA
    05 SPORT 4x4
    or it might actually be the body mount. its just on the inside of the tire the metal rail that runs at a 45.
  5. Jan 11, 2010 at 5:23 PM
    lilredenfield03
    Sylvania, GA
    well you have a 285/70/17 which a little wider than my 285/75/16 bfgs so i cant really help you with the trimming issue because i didnt have to trim but the front plastic in the inner wheel well and a tad bit on the backside. The wider the tire the more you have to trim.
