Wheel Spacer Help
Discussion in '1st Gen. Tacomas (1995-2004)' started by StAndrew, Apr 18, 2011.
  1. Apr 18, 2011 at 6:26 AM
    StAndrew
    StAndrew [OP] Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Im looking for some wheel spacers and need some help.
    So far Ive found two distinct types:
    -Ones you slide onto your lugs, put the wheel over it and bolt them both on.
    -And then the ones you bolt on to your lugs and then bolt the wheel onto the spacer.
    I dont want more than an inch and Im not looking to spend a fortune so I looking at some 5/16" spacers that slide onto the lugs.
    First question: Will these potentially unbalance my tires?
    Second: Am at risk of short threading my wheels?
    Thanks.
  2. Apr 24, 2011 at 2:54 PM
    JayARRGHH
    JayARRGHH Well-Known Member
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    285/75/R16 Eldarado MTZ, Alpine CDE-102 Deck, DIY Snorkel, 2" Spacer Lift, Uniden Bearcat 880 CB, Custom over head console w/ map lights, CB Mount, and external CB speaker, 2 12" Kenwood Subwoofers, 300 Watt Alpine Amp, Alpine 3" lift 500# capacity
    the ones with separate lugs on them, those are adapters, those are the ones you want. im actually just about to place an order on allprooffroad.com but im just trying to figure out the hubcentric vs lugcentric issue. There are some people selling them on here too.
  3. Apr 24, 2011 at 3:07 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    does spidertrax make a set for you, i would highly recommend them over any other spacer due to their great feedback and solid reputation
  4. Apr 24, 2011 at 3:08 PM
    08pretaco
    Oliver
    az
  5. Apr 24, 2011 at 11:11 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Yes, you will lose 5/16" of threads. I will never take that risk on my truck. Reconsider your options. Either a bolt on adapter or wheels with the correct backspacing.
  6. Apr 24, 2011 at 11:12 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
  7. Apr 24, 2011 at 11:39 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    was a thread a while back too about spacers. Couple guys were running ebay ones..
