Wheel Spacer Opinions?
Discussion in '1st Gen. Tacomas (1995-2004)' started by taylorholt5, Nov 27, 2011.
  1. Nov 27, 2011 at 7:15 PM
    taylorholt5
    taylorholt5 [OP] Well-Known Member
    Taylor
    California
    01 Prerunner SR5 TRD
    6 inch fabtech lift, trailer hitch unit, camper shell, k&n cold air intake, hankook mud terrain tires 35", bed liner, prerunner bar, hella off road lights, American Racing rims(black), rancho shocks, CB radio, Sony head unit.
    If i got 2 inch wheel spacers how would that effect my tacoma? Would there be any reason that my wheels would fall off or my wheel bearings go out? What are the precautions. I just want to know.
  2. Nov 27, 2011 at 8:00 PM
    Phuket
    Phuket Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
    most people run the spidertrax 1.25" spacer, and from what i've seen they have no problems what so ever
  3. Nov 27, 2011 at 8:39 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    +1....
    why do you want to go with 2'' wheel spacers? Thats a lot, and seems unnecessary.
    The only problem you could run into with wheel spacers is prematurely wearing out your wheel bearings.
  4. Nov 27, 2011 at 8:43 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    This.
    2" is a bit much. You may get some unwanted rubbing on the fenders with that much. As long as they're installed properly, there's not much to really worry about. I'd go with the spidertrax 1.25" as mentioned above.
  5. Nov 27, 2011 at 10:29 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I have 1.5'' Allpros. More then enough and work great! Be sure to get ET lugs too, especially for the front!
  6. Nov 28, 2011 at 8:20 AM
    wesb1023
    wesb1023 Well-Known Member
    Westley
    Eastern NC
    04 Double Cab
    I am currently running the spidertrax wheel spaces with no issues. I used to have a f-150 that I ran a set of 2" spacers on that I got off eBay. They worked great, and I really don't see the difference in a 2" wheel spacer and a wheel with 2" less backspacing so it really depends on the wheel setup as well as the spacer. If you already have them, put em on there!! Nothing like seeing it with your own eyes!!! Just be sure to loctite the inner studs, and torque everything to spec.
  7. Nov 28, 2011 at 8:25 AM
    wesb1023
    Westley
    Eastern NC
    04 Double Cab
    Just reread your post, you have not bought any yet.....ok I would recommend the spidertrax. They also sell 1.5" spacers but are not for the hub eccentric wheels. You could go with them if your wheels take the acorn style lug nuts. Otherwise the 1.25 is plenty.
  8. Nov 28, 2011 at 4:40 PM
    John Cheong
    John Cheong Active Member
    East Bay, CA
    2001 SR5 PreRunner
    33" falken rocky mountian A/T, 3.5" fabtech lift, Deck plate mod, Painted badges.
    wheel spacers or more backspacing on your wheels is going to wear out your wheel bearings alot faster because your putting more leverage farther out. its like if you hold a metal pole with one hand in the middle (which is stock) and holding it on the outside (which is like with wheel spacers ect.) and it just puts more stress on it. my only advice is not to buy the cheap ones, dont over kill it and torque everything to spec. im actually planning on getting 1.25" ones soon
  9. Nov 28, 2011 at 4:43 PM
    Rebel Taco 22
    Rebel Taco 22 mall crawler
    This.
    I run these very hard and have had zero problems.
  10. Nov 28, 2011 at 9:13 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    I run ebay spacers offroad and have no issues. Why do you need 2 inches? It seems excessive. The wider track width will add more stress to your wheel bearings but nothing too terrible. Just make sure to use loctite and check your nuts.
  11. Nov 28, 2011 at 9:57 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I have 1.5" on my rear axle to even things out from the extra width added by the spindles. They put more stress on wheel bearings and axle shafts (at least in the rear) but our trucks (especially in the rear) are light enough that it shouldn't make much of a difference. At least that was the consensus myself and my old shop teacher (a BMW master tech and avid 'yota 4X4 fan) came to.
  12. Nov 29, 2011 at 5:24 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    scrub radius is affected. ..but i don't think it matters that much in a lifted truck.
  13. Nov 29, 2011 at 6:12 AM
    Btnewman
    Btnewman Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
    I am thinking about getting the 2 inch ones for my truck as well. I want to fill the width of my baja fenders (at least until I can save enough to long travel my truck).I am curious to know how well they work for you
  14. Nov 29, 2011 at 8:24 AM
    wesb1023
    Westley
    Eastern NC
    04 Double Cab
    Every Ford dually on the road uses a cast iron 4" wheel spacer from the factory. Wheel spacers are not a new thing, they can be very safe and economical as long as they are installed correctly. I don't think a 2" spacer would give any more trouble than a 10" wide wheel would.
  15. Dec 19, 2016 at 7:40 AM
    Highwama85
    Highwama85 Member
    Sonoma County
    Sr5 dc
    Lumber rack, dual side rail tool boxes
    Would 2" spacers rub with stock 2nd gen sr5 rims? I don't see how bearing failure is relevant considering larger tires and rim back spacing would have the same effect.. I would prefer a wider track to counter roll caused by full lumber rack, and side rail tool boxes.
  16. Dec 19, 2016 at 9:48 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Depends on the tire width.
    Again, the furth you push the tire out the more it's going to eat the lower front fender while turning
    Also 2" spacers aren't going to make it suddenly feel more stable. So if that's your reason for running them I wouldn't bother. even more so if it's on 2nd gen wheels and they won't poke out much to begin with even with 2" spacers.
  17. Dec 19, 2016 at 10:22 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    I'm running 1.25 rear and 1.5 front 1.5 lift. Wheels line up perfect with a rare rub if turned hard and hit a bump. Inside back fender plastic. (example: turning off street with steep curb entry)
    Supreme Engineering Group http://stores.ebay.com/Supreme-Engineering-Technologies?_trksid=p2047675.l2563 really nice quality and machining. Truck drives as smooth as it did before i put them on.
    They are lug centric and hub centric.
  18. Dec 19, 2016 at 10:51 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Am i wrong in thinking wheel spacers really wont affect body roll at all as it doesn't actually change system geometry of the ifs? Soo the body weight will have same affect over the suspension regardless if the wheels are out farther (this will help with preventing rollovers/stability)
  19. Dec 19, 2016 at 10:54 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yes.
    It will change it a bit but not enough for you to notice.
    If you want wider for more stability then get a long travel kit. Though again that seems like a silly reason to get long travel.
  20. Dec 19, 2016 at 4:46 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Add a rear sway bar.
