Wheel spacer problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma414, Jan 14, 2013.
  1. Jan 14, 2013 at 8:14 PM
    Tacoma414
    Tacoma414 [OP] Well-Known Member
    Cody
    Agua Dulce
    06 PreRunner SR5 4.0L
    Flowmaster Exhaust 2" spacer lift 09 Tails blacked out Black headlight mod 6000k HIDs/Foglight mod Fog Light Mod 20" LED Light Bar Behind Grille Billet Grille Color matched mirros, doorhandles and bumper 5% tint all around Pioneer 4300dvd 2 10" kicker CVRs Alpine speakers Dome light: Blue LED Map light: White LED
    So I got a pair of spidertrax 1.25" spacers, cause there's a little nipple sticking out on the stock spindle that was rubbing on my 285/75/16 Yokohama geolanders and put about a 1/4 inch grove in my front tires that I didn't know about, I put the wheel spacers on and it stopped that but now my truck has a rubbing feeling when I start turning and it's not good, it was totally fine before without them I just didn't want the grove to go through my side wall and blow the tire, any ideas why the spacers made my truck feel like it's gonna fall apart?
  2. Jan 14, 2013 at 8:15 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Sounds like you're rubbing the fender or the cab mount
  3. Jan 14, 2013 at 8:17 PM
    Tacoma414
    Cody
    Agua Dulce
    It drove fine for about 15 mins when I put them on then on my way home it started doing that, I have rims on with a little offset but not enough, and my tires were a little cambured to which doesn't make sense
  4. Jan 14, 2013 at 8:19 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    ^X2. Pushing the tire out farther increases the turning radius and will lead to rubbing. Your better off rubbing here than the UCAs or spindle. Looks like you need to do some trimming and maybe cab mount chop. You cant trim your UCAs or spindles so spacers were a good choice.
  5. Jan 14, 2013 at 8:21 PM
    Tacoma414
    Cody
    Agua Dulce
    Well I'm getting OME 885s with 5100s soon and getting rid of my 2" spacer lift so would that help? And would 285/70s be better then 75?s
  6. Jan 14, 2013 at 8:25 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    885s will help but wont solve the issue if you flex the suspension. Lifting that high may also throw of your alignment, causing you to lose caster to get camber and toe in spec. Less caster means more rubbing in the back of the wheel well. Smaller tires will help but you are better off going with a skinnier tire than 285s i you want no rubbing. Your best solution here is to trim. Turn your tires at full lock and see here they rub. Then cut more than you think you need because when the suspension flexes rubbing gets worse
  7. Jan 14, 2013 at 8:25 PM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    You probably just want to do/get a CMC and trim your fenders a little
  8. Jan 14, 2013 at 8:30 PM
    Tacoma414
    Cody
    Agua Dulce
    What's the next size down in tires? Cause I love the look and stance with the bigger tires and spacers, but what would be skinnier?
  9. Jan 14, 2013 at 8:32 PM
    OZ-T
    Peter North
    British Columbia
    Just trim
  10. Jan 14, 2013 at 8:36 PM
    Tacoma414
    Cody
    Agua Dulce
    I don't rub on the cab it only rubbed on the front plastic piece that hangs down below the front fender well and the UCAs and LCAs have a little polish to them but I'm wondering about shaving down the nipple on the spindle and see if it's fine without the spacers
  11. Jan 14, 2013 at 8:37 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    265/75/16 But like every one else is saying. Trim. Tires are expensive, and you might not be happy with something smaller.
  12. Jan 14, 2013 at 8:38 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Cut plastic NOT your spindle!
  13. Jan 14, 2013 at 8:39 PM
    Tacoma414
    Cody
    Agua Dulce
    Wb a skinnier tire so it doesn't rub on the nipple
  14. Jan 14, 2013 at 8:41 PM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    I don't know if changing your lift will help. You need to push the tire out some so it doesn't rub on the spindle nub not so far that it rubs other places when you turn.
    If there is a thinner spacer, maybe that would work. Other option is wheels with different backspacing.
    I think I've seen 1/4 inch spacers somewhere...
    Yes, 1/4, 3/8, and 1/2. Someone else will need to chime in about whether the studs are long enough to work with these spacers. They might not leave enough thread. Also not sure about center bore diameter.
    http://www.summitracing.com/search/...wheel-spacers/wheel-bolt-pattern/6-x-5-1-2-in
    If the 1/4 inch spacer will fit the hub, they're cheap enough to be worth trying at least.
  15. Jan 14, 2013 at 8:42 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    That would work but what about some trimming so you dont need new tires. You said its just the plastic in the front part of the wheel well? Mine is gone to fit 285s.
  16. Jan 14, 2013 at 8:56 PM
    Tacoma414
    Cody
    Agua Dulce
    Well my tires are so bald anyways I just wanted to fix the problem before I got new ones, I'm thinking about 1/4" spacers, and I need new suspension, I have the spacer lift anyways
  17. Jan 14, 2013 at 9:15 PM
    logcabinwc
    logcabinwc Well-Known Member
    Micah
    SF East Bay
    08 4d 4x4 White V6 TRD
    Old Man Emu 885s with Nitrocharged 90000, Bilstein 5100 in the back with AllPro 3 spring progressive AAL, 16 inch Baja Black 6-spoke alloy wheels, Flow Master exhaust, bed lights, Pioneer HD radio, Uniden CB Radio, K&N Air filter, BAMF Sliders w/kickout, Relentless Aluminum IFS Skid, 24 LED light bar, custom/homebuilt expedition style bed rack and basket combo, and Body Armor rear plate bumper.
    I know everyone else is talking about tires and trimming and stuff... but did you take the wheel off and retighten all the bolts on the spacer? All the instructions I looked at when I was getting spacers says to drive ten miles, then pull the wheels off and retighten.
    From your description I just couldn't tell if the rubbing feeling happens whenever you start turning, or just at a full turn...
  18. Jan 14, 2013 at 9:16 PM
    Tacoma414
    Cody
    Agua Dulce
    Yeah I need to do that, that's probably what happened, they were my friends, he let me borrow them cause he wasn't using them so I didn't have instructions so that should fix it hopefully
  19. Jan 14, 2013 at 9:22 PM
    logcabinwc
    Micah
    SF East Bay
    ya God forbid your wheel comes off while your driving. just make sure you torque them correctly... I can't remember if they are different from the wheel lugs, but I have all pro and not spidertrax. Im sure their website will have the instructions though, or someone else on this forum knows
  20. Jan 14, 2013 at 9:24 PM
    Tacoma414
    Cody
    Agua Dulce
    Yeah I'm gonna check that in the morning and drive around the block, it keeps happening I'm just gonna take them off
