wheel spacer question
Discussion in 'Wheels & Tires' started by Tacoma414, Nov 21, 2011.
  1. Nov 21, 2011 at 6:36 PM
    Tacoma414
    Tacoma414 [OP] Well-Known Member
    Cody
    Agua Dulce
    06 PreRunner SR5 4.0L
    Flowmaster Exhaust 2" spacer lift 09 Tails blacked out Black headlight mod 6000k HIDs/Foglight mod Fog Light Mod 20" LED Light Bar Behind Grille Billet Grille Color matched mirros, doorhandles and bumper 5% tint all around Pioneer 4300dvd 2 10" kicker CVRs Alpine speakers Dome light: Blue LED Map light: White LED
    you can put wheel spacers on after market rims right?
  2. Nov 21, 2011 at 6:41 PM
    ST3VE
    ST3VE IG: @fishsohard
    MD --> SC
    Tint, car seat, baby wipes
    yes. I have 3" spidertrax on my procomp rims.
  3. Nov 21, 2011 at 6:43 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    You can, but it can pushthe tire out so far that you can have rubbing on the outside of the tire
  4. Nov 21, 2011 at 8:07 PM
    Tacoma414
    Cody
    Agua Dulce
    what do you mean rubbing on the tire? i have 33" yokohamas, with 16" mb rims, and would i need hub centric or lug centric
  5. Nov 21, 2011 at 8:16 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    pushing the wheels out can cause other areas to rub. it all really depends on your setup. nevertheless, always try to use hub-centric adapters when you can. spidertrax and all-pro both sell adapters that is both hub and lug centric.
  6. Nov 21, 2011 at 8:25 PM
    Tacoma414
    Cody
    Agua Dulce
    i want to go 2" out
  7. Nov 21, 2011 at 8:30 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    I don't see why you would want wheel spacers if your rims have the correct back spacing... Unless your going for the poser LT look.
  8. Nov 21, 2011 at 8:33 PM
    Tacoma414
    Cody
    Agua Dulce
    because my tires rub to much, and the poser LT look? no thats spacers with flared fenders
  9. Nov 21, 2011 at 8:36 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    What are you rubbing on? 2" is a lot, you'll rub even more.
  10. Nov 21, 2011 at 10:00 PM
    Tacoma414
    Cody
    Agua Dulce
    my UCA LCA, and theres a piece thats the size of a marble thats rubbing on the inside, and the tire guys said it can heat up my front tires and can make them pop if it gets to hot
  11. Nov 22, 2011 at 5:57 AM
    TexasTacoma37
    I mean the tire will rub on the fender.
    And you always want to buy hub-centric if the wheel you want is offered in a hub-centric (for toyota) version. Otherwise, lug centric will do. You can get some extended-thread lugs to help center the wheel better if you like.
  12. Nov 22, 2011 at 1:20 PM
    Tacoma414
    Cody
    Agua Dulce
    the wheel spacers are only for a couple months if that, my tires are almost up and im getting new rims with an off set, what size spacers would you reccommend KPT and its $9 for extended thread lugs so ill get those, i want the stance you have
  13. Nov 22, 2011 at 2:28 PM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    If you're less than 2 months away from new wheels anyway, just get new wheels now. Why spend money on wheel spacers that you're only going to use for a month or two? Doesn't make much sense.
  14. Nov 22, 2011 at 2:29 PM
    TexasTacoma37
    So you are currently running stock rims, and you want them to stick out as much as mine? Just making sure we are on the same page here.
    Or you have aftermarket rims, then what is the backspacing and width of them?
  15. Nov 22, 2011 at 2:31 PM
    BrettBretterson
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    Correct me if I'm wrong OP, but I think he's running MB 72's.
  16. Nov 22, 2011 at 2:35 PM
    TexasTacoma37
    Alrighty. If that is the case, what is the width and backspacing of them?
  17. Nov 22, 2011 at 2:41 PM
    Tacoma414
    Cody
    Agua Dulce
    see thats the problem, they came with the truck so i have no idea, they are off the truck right now, ill go measure them right now
  18. Nov 22, 2011 at 2:43 PM
    TexasTacoma37
    There should be something stamped on teh wheel like "16x8jj ET 10" or something like that. Post that code here.
  19. Nov 22, 2011 at 2:49 PM
    yota new.o
    yota new.o Well-Known Member
    joe
    klamath falls oregon
    96 tacoma 2.7 sr5
    fabtech dirtlogic coilovers with all-pro a-arms chevy 63" leaf springs billi 5125 12" extended bore shockins in rear headache rack duplicolor bed armor bumpers kc daylighters front fenders corbeau racing seats custom bed rack
    i rubbed on the a arm and frame and two inch spacers cured that now i have no issue just because you move the tire does not mean youll rub more it all depends on where the rub is ocuring and when depending on suspension flex turn radius all that jazz
  20. Nov 22, 2011 at 2:49 PM
    Tacoma414
    Cody
    Agua Dulce
    well the backspacing is 6" and it looks like the width is 9-10" i couldnt find anything stamped on the rim
