Wheel Spacer Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Shades_Of_Red, Nov 18, 2020.
  1. Nov 18, 2020 at 12:09 PM
    Shades_Of_Red
    Shades_Of_Red [OP] Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    Does anyone have 3/4" either Bora or Spidertrax wheel spacers with the 16" black tacoma pro wheels installed? If so did you have to modify/grind anything on the stock studs in order to install them?
  2. Nov 18, 2020 at 12:33 PM
    ELVIS
    ELVIS Well-Known Member
    Paul
    TX
    2020 TRDOR
    not 100% sure, but i have the 1.25 and they are fine. i think i read its the 1inch or less you gotta grind studs.
    71tattooguy likes this.
  3. Nov 18, 2020 at 12:58 PM
    Anderson5290
    Anderson5290 Well-Known Member
    Brandon
    Corona, Ca
    2018 Tacoma TRD OR 4x4
    Tuned Fox 2.5 resi with dsc, JBA HD UCA, total chaos knuckle gussets, rear trd pro fox shocks, Deaver U402 stage 1 rear leafs, archive garage u bolt flip with fox 2.0 air bumps, White knuckle off road rock sliders, BAMF 1/4” steel skids, Magnaflow exhaust, Archive Garage Hammer Hangers, Cbi high clearance rear bumper, 285/75/16 tires.
    Usually with stock wheels you can fit 3/4 spacers because the wheels are not completely flat on the mounting surface. I didn’t have to cut my studs when I had 3/4 spacers on the front and back.
    na8rboy likes this.
