Wheel spacer questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ak4T777, Jan 23, 2017.
  1. Jan 23, 2017 at 6:58 PM
    Ak4T777
    Ak4T777 [OP] Well-Known Member
    Kevin
    2003 Tacoma crew cab
    OME lift 3" lift 1.5" lift shackles Aftermarket bumpers 1" body lift
    Looking at the 1.5" spider trax spacers. Looked at previous threads on spacers but couldn't find anything stating if they are safe at freeway speeds? Say 65mph - 80mph? Or are they just recommended for offroading?
    I know a lot of shops here won't touch vehicles w spacers. (I'll just rotate my tires as needed myself.) Good thing is, I only put 3,000 miles on the truck over a 6 month time span :) mostly in town driving but sometimes at highway speeds.
    Should I check the spacers every month?
  2. Jan 23, 2017 at 7:05 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    When you install, use the red locktite on the HUB studs then torque to spec. Torque lug nuts on spacer studs to spec, check after (I think it was 20 miles). Basically just follow the directions. If you want to check every month, go ahead.
    Hub centric SpiderTrax are fine for highway use. However, DO NOT USE CHEAPO LUG CENTRIC SPACERS.
  3. Jan 23, 2017 at 7:06 PM
    My02SC
    My02SC instigator
    Frank
    Jersey Shore ,PA
    2003 Tacoma,TRD
    2.5 lift, the usual that goes with it. Work in progress.
    Make sure you get hub centric. In pa anything over .5" is not legal for inspection but nothing is really ever said.
  4. Jan 23, 2017 at 7:07 PM
    Scoobarooo
    Scoobarooo Well-Known Member
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    3" OME/Bilstein, Retrofits, Custom Bed rack/Toolbox, Amsoil Everything, tons of others.
    Spidertrax or G2 spacers should be fine.
  5. Jan 23, 2017 at 11:05 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    You'll want to change front wheel studs out with rear wheel studs. They're a little longer and allow you to get a full nuts thread. Thats they way 04 was. I'm not running spidertracs but something similar. 1.5 fronts and 1.25 rears.
  6. Jan 23, 2017 at 11:09 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Mine are Supreme Engineering Technologies
