Wheel spacers causing bearings to fail?
Discussion in 'Long Travel Suspension' started by Nicks4x4LT, Dec 1, 2011.
  1. Dec 1, 2011 at 12:16 PM
    Nicks4x4LT
    Nicks4x4LT [OP] Official Villain
    Nick
    714 Orange county
    2010 4x4 V6
    Custom front bumper, Icon 2.5 ext. travel coilovers, Defined rear long travel King smooties w/ resi. Avid Offroad sliders, Fiberwerx front fenders, Glassworks Shorty TT style rear glass, URD MAF calibrator, DT shorty headers, URD TCAI, Magnaflow catback
    Can anyone think of a reason why a wheel spacer would cause my wheel bearing to go out. The reason i ask is my truck has been at the dealer getting the brakes bled and looked at due to a "spongy" pedal i have been experiencing. So they replaced my master cylinder on the brakes and bled them, called back saying the brakes hadnt improved. Early today toyota tech called and was saying the wheel spacers or the gusseted spindles may have caused the bearing to fail. Please tell me what you think. Sounded kind of fishy to me. thanks:(
  2. Dec 1, 2011 at 12:18 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Wheel spacers can definitely cause a wheel bearing to fail quicker. It puts more stress on the bearing since it spaces the wheels out and gives them more leverage on the bearing. I don't see how wheel bearings could give you a spongy brake pedal though...
  3. Dec 1, 2011 at 12:18 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Wheels spacers and aggressively backspaced wheels put more strain on the wheel bearings from what I read somewhere iirc
  4. Dec 1, 2011 at 12:19 PM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Bingo. Simple geometry and physics.
  5. Dec 1, 2011 at 12:24 PM
    Nicks4x4LT
    Nick
    714 Orange county
    2010 4x4 V6
    also forgot to mention this only happened on one side. i understand about the leverage but i would think it would have happened on both sides.
  6. Dec 1, 2011 at 12:24 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Factory setup has the bearing roughly centered (left to right) on the wheel and tire.
    Move the wheel inboard or outboard from that, and you can see how the rim is now applying torque to the spindle through the bearing, that likely mow exceeds the design spec for loading in that direction.
    1stTacoDre and freedomriding like this.
  7. Dec 1, 2011 at 12:27 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    One sides going to tend to fail first. Replace that one and the other will go eventually.
    Minor overloading equates to shorter service life, not immediate failure.
  8. Dec 1, 2011 at 12:29 PM
    Pugga
    Massachusetts
    If the bearing is bad on one side, the other usually isn't too far behind in most cases.
  9. Dec 1, 2011 at 12:30 PM
    korslite
    korslite Well-Known Member
    Justin
    Bellingham, WA
    DCLB Sport
    FOX 2.5 RR's, TC UCAs, TC Spindle Gussets, Allpro Expedition leaf pack, Fox 2.O RR w/ Comp adjusters, 17" ATX Artillery, BFG AT 285's, de-scooped, custom sliders, custom bedrack, Brute Force Fab bumpers, Smittybilt XRC8 winch, ARB locked Rear diff
    I just went through this issue with the spongy pedal a little while back. It was actually caused by a bad wheel bearing. Here's why: The bearing was bad enough that when i would go around a left hand turn it would load that bad bearing on the right side due to normal weight transfer. The load would cause the bearing to wobble, in turn causing the rotor to wobble in the caliper spreading the pads beyond their normal tolerance or gap. When the brake pedal was depressed the next time the pads on that side would move the normal amount but this would not be enough travel to engage the rotor. It would then take a second pump of the pedal to engage the rotor and braking power would be restored to normal. Replaced both wheel bearings and presto, no more spongy pedal. Hope this helps.
    Scott4032 likes this.
  10. Dec 1, 2011 at 12:31 PM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    Yep. Pretty well known issue in the 'car scene'.
  11. Dec 1, 2011 at 12:32 PM
    GP3
    California
    4X4 TRD Off Road
    :eek:
    I will have to remember this. That's pretty wild sounding, but makes complete sense.
  12. Dec 1, 2011 at 12:32 PM
    Nicks4x4LT
    Nick
    714 Orange county
    2010 4x4 V6
    when you say shorter service life, do you mean like 2000 miles?, I installed the spacers roughly 2000 miles ago, and the total mileage on the truck is about 15k.
  13. Dec 1, 2011 at 12:34 PM
    Nicks4x4LT
    Nick
    714 Orange county
    2010 4x4 V6
    very helpful! thanks a bunch:D Do you recall approximately how many miles you had when they were replaced?
  14. Dec 1, 2011 at 12:35 PM
    Nicks4x4LT
    Nick
    714 Orange county
    2010 4x4 V6
    also im assuming taking the wheel spacers off would be a good decision then haha:p
  15. Dec 1, 2011 at 12:40 PM
    Pugga
    Massachusetts
    Whoa, crazy but I guess that does make sense. Good info there, I hadn't thought about that! :thumbsup:
    Shorter service life is arbitrary, it depends on the truck's use and maintenance schedule. It's like any wear part, for example some people are replacing their pads and rotors at 15k miles and some are at 90k miles still stock. Wheel spacers do add more stress to the wheel bearings but how that translates to service life is not an exact science.
  16. Dec 1, 2011 at 12:42 PM
    Nicks4x4LT
    Nick
    714 Orange county
    2010 4x4 V6
    Gotcha, thanks for helpin out a rookie:D
  17. Dec 1, 2011 at 1:51 PM
    korslite
    Justin
    Bellingham, WA
    DCLB Sport
    Hey no problem. I was hoping someone could learn from what I went through figuring this out. I started with the master cylinder too. Ended up replacing that, rotors, calipers, pads, then the wheel bearings when I discovered what was really going on. It was a fun process. But no stealership got my money at least. Did all the work myself.
    I had about 86k wheb i did the bearings with about 10 or 12k with aftermarket wheels and tires. 285's on 17x9 wheels. Think that's what finished mine off.
  18. Dec 7, 2011 at 1:42 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    As others have stated, wheel spacers do add stress to your wheel bearings. You have to see how far out the wheel backspacing combined with the wheel spacer pushes your tires out.
    Also if you have a 2nd gen (2005+) tacoma, the wheel bearings tend to fail a lot more often than 1st gens.
    Yours seemed to have failed quite rapidly but maybe its because of a bad batch possibly. I heard they usually go bad around 50-70k unless you are romping crazy offroad. Try out Timken bearings or stick with OEM. DO NOT buy NAPA or other crap.
    I have a 99 tacoma and my front wheel bearings went out at 140k including severe offroading. My rears are still holding up it appears. I run 1.25 spacers in the back. Hope this helps.
  19. Dec 7, 2011 at 1:46 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    worn bearing can cause spongy brakes... what happens is the rotor doesnt spin true anylonger when the bearing has play in it.... the rotor"wobbles" and spreads the pads apart. then when u go to push the pedal... the pads have to make up the space and contact the rotor...
  20. Dec 7, 2011 at 2:51 PM
    korslite
    Justin
    Bellingham, WA
    DCLB Sport
    My OEM bearings appeared to be Timkens when removed and compared to the new Timken bearings I bought. Best part is they were half the price of the "Toyota" parts.
