wheel spacers for 285's?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jcremeans11, Jan 2, 2011.
  1. Jan 2, 2011 at 11:47 AM
    jcremeans11
    jcremeans11 [OP] Well-Known Member
    Jon
    Ohio
    01 Tacoma SR5
    Spectre Cold Air Intake, Michelin XLT's (265/70/16), Escort Solo S3, Grounded Throttle body
    With a 3" lift, would you need wheel spacers to run 285's? Everything else is stock
  2. Jan 2, 2011 at 11:50 AM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    Depends on backspacing on the wheels. Short answer is depending on how much rubbing you're willing to put up with and how much trimming you're willing to do.
  3. Jan 2, 2011 at 11:55 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Stock backspacing on the 1st gens is 4.5"
  4. Jan 2, 2011 at 1:50 PM
    jcremeans11
    Jon
    Ohio
    01 Tacoma SR5
    Do wheel spacers hurt your power much?
  5. Jan 2, 2011 at 1:51 PM
    wtbthree
    wtbthree Well-Known Member
    I didn't. I'm running 17" OEM FJ rims. Only needed to remove my front flaps and do some very very minor cutting on my fenders
  6. Jan 2, 2011 at 2:39 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    If you run wheel spacers, you are going to need to cut some of the plastic out of the fender wells out as well as doing the pinch-weld mod because the tires will rub it when they are near full lock. Then you'll be golden.:)
    No, not at all.
  7. Jan 2, 2011 at 3:35 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    why do people assume this? i feel like I've seen people ask this a couple times this month but before hand i had never even heard of it. I'm guessing it's because it's adding unsprung weight but my 4 spidertrax weigh 15 lbs total....no where near enough to cause a noticeable difference
