Wheel spacers. New wheel studs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kxlbe, Apr 13, 2022.
  1. Apr 13, 2022 at 6:40 AM
    Kxlbe
    Kxlbe [OP] Member
    2021 Red Tacoma SR
    I’m getting 10mm wheel spacers to help clear the front caliper on my truck. I was wondering if I’ll need to extend my wheel studs. And if so any recommendations on what brand/size. I assume 10mm longer ones will work.
  2. Apr 13, 2022 at 6:49 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I would avoid any spacers that aren't hub-centric like Spidertrax or Bora
    QChawks likes this.
  3. Apr 13, 2022 at 6:50 AM
    Kxlbe
    Kxlbe [OP] Member
    2021 Red Tacoma SR
    Damn. I already ordered them off custom offset like 4 weeks ago. And they’re bora.
  4. Apr 13, 2022 at 6:56 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Bora is good. Post a pic of them
  5. Apr 13, 2022 at 6:57 AM
    Kxlbe
    Kxlbe [OP] Member
    2021 Red Tacoma SR
    I’ll post one later. They are supposed to arrive today. I don’t currently have a picture
  6. Apr 13, 2022 at 7:44 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Pretty sure @b_r_o was recommending spidertrax and Bora in his response, which I concur.
  7. Apr 13, 2022 at 7:53 AM
    D-Bag
    D-Bag Well-Known Member
    Derik
    2014 Tacoma Baja
  8. Apr 13, 2022 at 8:29 AM
    Elikk
    Elikk Well-Known Member
    Eli
    Tacoma Trd sport crew cab 2011
  9. Apr 13, 2022 at 8:42 AM
    D-Bag
    Derik
    2014 Tacoma Baja
    The knurl diameter needs to be 14.2mm. The one you listed is 14.48mm in diameter. Did you drill your hub flanges out?
  10. Apr 13, 2022 at 10:24 AM
    Elikk
    Eli
  11. Apr 13, 2022 at 11:18 AM
    Waasheem
    Waasheem
    2007 xrunner
    Arp makes really nice wheel studs, obviously more dense better material than stock.
  12. Apr 13, 2022 at 11:45 PM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    Just FYI, the density of steel isn't really a good indicator of strength--for example 4340 is significantly stronger that 1018, despite 1018 being slightly more dense. And even then most steels fall in the 7.7-8.0 g/cm^3 range, so there isn't much variance there anyway (unless we are talking about some specific tool steels, but that's not really applicable here anyway).
