Wheel spacers or not??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by soupman77, May 5, 2011.
  1. May 5, 2011 at 8:44 PM
    soupman77
    soupman77 [OP] Well-Known Member
    Alan
    Texas
    08' 4DR Tacoma LB 4x4 TRD Sport
    Revtek 3" Leveling kit with 1.25" in rear. Grillecraft mesh grill with TRD emblem, Hella 500's mounted behind grille, horn relocation, blacked out lower valence, allpro offroad bumper, blacked out roof, and so much more to do...
    I just put a Revtek leveling kit on my 08 TRD Sport and Nitto Terra grappler 285/70/17s, but noticed a slight rub when turning hard or doing the same in reverse. My question is in regards to using Spidertrax wheel spacers...would they work, and are they recommended? As far as state law, I live in Texas if that helps...
  2. May 5, 2011 at 9:35 PM
    BarefootBandit
    BarefootBandit Well-Known Member
    TC UCA OME 884 5100 TSB+AAL 4.10 V6 6spd 285/75/16
    With stock rims you will absolutely need 1.25" spacers.
  3. May 6, 2011 at 6:29 AM
    soupman77
    Alan
    Texas
    Thanks dude. Kinda figured so, but got different answers.
  4. May 6, 2011 at 7:51 PM
    soupman77
    Alan
    Texas
    Hub centric or lug centric? I looked at spidertrax, but am just learning what these two terms mean.
  5. May 9, 2011 at 4:44 PM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    im reading about the same thing right now and the spidertrax seem to be the best to buy from everyone's opinion
  6. May 9, 2011 at 4:51 PM
    yachtsmith
    yachtsmith Member
    Aaron
    Seattle
    TRD DC Sport
    Lots.....
    I have a set of Spidertrax on mine and I love them. Half-way through my build I realized that the wheels I wanted in the size I wanted them in had the wrong backspacing. So....Spidertrax to the rescue!!!! I haven't done much wheeling yet but they seem to be very well built and machined to exacting specifications.
  7. May 9, 2011 at 4:53 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    do you notice any mpg loss? I know mathmatically you HAVE to lose a bit the that tiny bit of aerodynamic loss, but i wonder if its noticeable?
  8. Jun 29, 2011 at 9:29 PM
    HAWAIICALIVEGAZ
    HAWAIICALIVEGAZ Desert Warrior
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Dr Coilovers; Camburg UCAs; Sway bar Relocation block; Deaver J66 Leafs; ProComp extended travel rear shocks 6K HIDs & 13" antenna
    I think the the difference between the two is that one actually uses the hub lip to center the spacer and that's basically what holds it there... and lug centric uses the lugs and nuts to center it. I could be wrong, but that's what I think.
  9. Jun 29, 2011 at 9:32 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Hub
