Wheel spacers or shortshifter first?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1tacoplease, Feb 16, 2009.
What should I get first?
  1. SPIDERTRAX WHEEL SPACERS
    21 vote(s)
    31.3%
  2. URD SHORTSHIFTER
    46 vote(s)
    68.7%
  1. Feb 16, 2009 at 1:11 AM
    1tacoplease
    1tacoplease [OP] I like my truck!
    Temecula
    2008 BSP 4x4 6 speed
    265/70/17 BFG RT's, FJ 17" rims with 1.25" spidertraxx Debadged, HID's, URD short shifter, Bilstein 5100's in the front, TSB and 1" block rear, URD TCAI with maf calibrator, JBL long tubes, DT Y pipe, Gibson exhaust, Walbro 255 fuel pump, Pioneer stereo, Bak flip G2 tonneau, TRD skid plate, MB Quarts all around with dynomat, Viper Alarm with motion sensor
    These are the two mods I'm about to buy, which one do I get first and why?
    URD SHORT SHIFTER
  2. Feb 16, 2009 at 11:15 AM
    1tacoplease
    Temecula
    I guess I got one vote for the shortshifter... I'm not too convinced.
  3. Feb 16, 2009 at 11:52 AM
    SilverSeven
    SilverSeven Rock Solid Toy
    Jordon
    South Jurzee
    6" 35s mud and scratched to shit
    wheel spacers are garbage.. I will never run them again.. one of the most dangerous modifactions one can do to a vehicle.
  4. Feb 16, 2009 at 1:47 PM
    1tacoplease
    Temecula
    Why do you say that?
  5. Feb 16, 2009 at 7:01 PM
    1tacoplease
    Temecula
    Man, it's an even split, no one else has an opinion?
  6. Feb 16, 2009 at 7:04 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Why do you feel that you need wheel spacers? Are you getting larger tires?
    I voted for the shortshifter. To me, it's no contest.
  7. Feb 16, 2009 at 7:15 PM
    1tacoplease
    Temecula
    Just wanted a beefier but stock look. Trying to stay clean with not too much bling but you can tell it's fixed up!
  8. Feb 16, 2009 at 7:35 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    the shortshifter actually has something useful to it.... makes shifting nicer and can be slightly quicker...
  9. Feb 16, 2009 at 11:33 PM
    1tacoplease
    Temecula
    But the wheel spacers ad a larger wheel base for wheeling and it looks good?
    What do you all think?
  10. Feb 17, 2009 at 7:17 AM
    SilverSeven
    Jordon
    South Jurzee
    wheel spacers lead to problems, bottom line, i know this first hand as i have had nothing but problems ever since i put them on. They came off after 2 weeks. Also, you will rub more than you do now with spacers, believe it or not.
    pretty much, dont buy wheelspacers. Our studs are so short they are dangerous, if you are doing anything down there, send your hubs in to get re-studded with AT LEASTE 2" studs..
  11. Feb 17, 2009 at 8:12 AM
    1tacoplease
    Temecula
    OK, so stay away from the wheel spacers if you don't want problems. Have you used the spider tracks? Will i notice more rubbing if i am using stock wheels and 265/75/16 only???
    Thanks
  12. Feb 17, 2009 at 8:18 AM
    SilverSeven
    Jordon
    South Jurzee
    I didnt run spidertrax, i ran the ones from JTS diffs, same thing basically, only the spidertrax are hub-centric and mine were lug-centric, but regardless, you are putting more leverage on everything, as well as creating a weak point.
    if you want a wider track, get less backspaced wheels
  13. Feb 17, 2009 at 8:27 AM
    1tacoplease
    Temecula
    S basically you're saying the only purpose for this os looks and no performance?
  14. Feb 17, 2009 at 9:41 AM
    SilverSeven
    Jordon
    South Jurzee
    yes, There is really no performance gain with them, a little more stability, but the amount of + change is not worth the negative effects.
    Narrower tracks are often perferred on the trail also for those tight spots
  15. Feb 17, 2009 at 9:42 AM
    SilverSeven
    Jordon
    South Jurzee
    if you want to try some, I will sell you mine for 50 bucks, but i would advise against it.
  16. Feb 17, 2009 at 9:58 AM
    1tacoplease
    Temecula
    You pretty much talked me out of it. I think I will just go with a short shifter instead. Thanks.
  17. Feb 17, 2009 at 11:04 AM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    Now this is an example of intellectual honesty. And it came from one of my south Jersey breathren.
  18. Feb 17, 2009 at 1:22 PM
    cannonemj7
    cannonemj7 Member
    Dupont, WA
    K&N CAI PIAA Xtreme White H4 Toytec 3" lift Front Spacers,Rear AALs Spidertrax 1.25" spacers Toyota Roof Rack
    I'd personally suggest the Shortshifter.
    As far as the spacer's go, I'm running the spidertrax on all fours. ABSOLUTELY no problems because I didn't go the cheap route. Spidertrax do not use your existing wheel studs for the wheel. Rather, your wheel studs are used to hold on the spidertrax spacer, the spidertrax spacer has it's own set up wheel studs (eliminating the problem of a short stud). Because they're hub centric, they better distribute the load from wheel/tire to your drivetrain.
    In short: if you choose spacers, only get spidertrax.
  19. Feb 17, 2009 at 2:12 PM
    SilverSeven
    Jordon
    South Jurzee
    JTS are the same thing, and they are NOT cheap.
    $50 offer still stands to anyone wanting to try em out
  20. Feb 17, 2009 at 2:53 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Someone correct me if I'm wrong but.. you might regret putting wheel spacers on the first time you get it off road and fully articulate the rear axle. More then likely you would end up ripping a fender flare off (stock flares) if you run plus size tires. As my truck stands with stock wheels, and 265/75R-16 tires, the flares are very close to the sidewall at full atric. Just some food for thought.
    Anyways I am all for the URD shifter. I've been wanting to do this mod myself for a while, but I have not had the extra money to throw at it.
