Wheel spacers (Spidertrax)- Do they reduce wheel well clearance?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Citadel, Jan 3, 2017.
  1. Jan 3, 2017 at 9:03 AM
    Citadel
    Citadel [OP] Well-Known Member
    Do Spidertrax spacers reduce wheel well clearance and can they cause cab mount rubbing?
    I did a CMC, installed 1.5" Spidertrax spacers and added 285/75/16's.
    I have slight rubbing on the cab mount at the rear of the wheel well.
    No rubbing on front of wheel well.
    Running 2017 TRD Pro 16" wheels
    Running SPC UCA. (D Setting)
    Caster 3
    Camber 0
    Toe 0
    No mud flaps
    Wheel well plastics trimmed
    tires- 285/75/16
  2. Jan 3, 2017 at 10:24 AM
    Omar RVA
    Omar RVA Well-Known Member
    Omar
    OR
    2020 Ram 2500 Power Wagon; 2019 Land Cruiser
    Short answer: yes. Any wheel spacer/adapter will give you clearance from tire to UCAs or Shocks but will increase your scrub radius. That said you didn't tell us what wheels you're running.
    Imagine being above your car and watching the wheel move as you turn the steering wheel. Now push that wheel outside of the wheel well an inch+ and imagine the same thing. You're going to rub on the edges that once made no contact.
    OA
