Wheel Spacers vs. Caliper Grinding
Discussion in '2nd Gen. Tacomas (2005-2015)' started by The Traveler, May 7, 2012.
  1. May 7, 2012 at 10:45 AM
    The Traveler
    The Traveler [OP] Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Please bear in mind, I'm very new to trucks and the dynamics of them...I've stuck to tuners for the last 7 years, but now I'm hooked on these! :D
    I'm in a tight situation where I was sold a set of 4 used wheels/tires from a fellow 2nd gen Tacoma owner, and he claimed they fit his Tacoma no problem. They are Ultra Type 164's wrapped in 285/75/16 BF Goodrich AT KO's. He had a 2007 4x4 DCSB, so basically the same truck I have but 3 years newer. Of course 33" tires wont fit on stock height without some decent trimming, which I have done to the point where I do not rub anywhere and I still have some of my wheel well to spare.
    The problem is where the front brake calipers meet the backside of the wheel spokes. The space between them is barely big enough to fit a single sheet of paper through on both sides. Under semi-hard braking (not engaging ABS but definitely nose-diving) I hear a significant grinding/scraping sound, but this will go away once the truck has been on the road for more than 10 minutes. Is this because of the AT's being cold? My mechanic buddy offered an explanation where the caliper is flexing and scraping against the wheel well.
    The bottom line is, I paid good money for these wheels and tires, and I'm determined to make them work. They look great and feel great and I got a amazing deal on them. What is my safest option?
    Wheel spacers - Spidertrax only makes them as small as 1.25" which will make my truck look like a wannabe prerunner (not the look I'm going for). How safe are these? I'm scared of using the generic 5mm 6 lug ones from Pep Boys...too many horror stories.
    Grinding down my caliper 1/16" to increase the distance from the wheel spokes...messing with the integrity of a part that saves my life every minute of driving, but it's only 1/16" taken off.
    What would you do in my situation? New wheels are not an option for me right now. I can put on my stock setup until I figure this out, but I really could use some help.
    Thanks in advance!
    Photos:
  2. May 7, 2012 at 11:19 AM
    dlg636
    dlg636 Active Member
    Darrin
    Honolulu, Hawaii
    4x4 Tacoma w/all the goodies
    DR front coils and rear shocks, deaver springs, load leveling airbags, k&n intake, JBA hedders and exhaust,Unichip power chip, URD short shifter, onboard air compressor, upgraded power inverter (1000W put in stock inverters location) budbuilt traction bar, warn transformer winch mount and warn winch, HID headlights and foglights, full LED bulb conversion, LED bed lights, full stereo system with GPS and they all roll on 16x8 black steel rock crusher and 285/75R16 BFG KM2's.
    i wouldn't grind the caliper. i only say this cause when i was putting on my rims, that's what 4WP did and they ground through the caliper. so i had them replace the caliper and rotor from a 2004 model one they had lying around just so i could get home seeing how it was a sunday and toyota was closed. its still 4 piston but just a little smaller. on the way home i did some hard breaking on and off-road just to see how they worked on the truck and they did great. so the next day, i had them pay for new brake pads, rotors and rebuild kits (which they gladly did since it was WAY cheaper then buying new 05 calipers) and i got to run the rims i wanted (black steel rock crushers). its been 7 years now and i've had no problems stopping.......yet lol. hope this helps you out.
  3. May 7, 2012 at 11:44 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2, I wouldn't grind the caliper either.
    Kolter45 likes this.
  4. May 7, 2012 at 11:45 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    dont grind the caliper
  5. May 7, 2012 at 11:49 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Lurry ground down his
    was not a good result :rain:
  6. May 7, 2012 at 11:51 AM
    XXXX
    sKiP
    05 Prius
    oh and any thickness wheel spacer can be purchased in 1/4" increments if my memory is correct from another company - I forget the name.
    wheel spacers are only slightly worse for your truck because they add another point to fail.
  7. May 7, 2012 at 11:51 AM
    cgs2k2
    cgs2k2 old man
    what happened?
  8. May 7, 2012 at 11:56 AM
    The Traveler
    SoCal
    I pretty much knew this would be the consensus, and I was not going to do it...but those seemed to be the only 2 options on the table.
    I guess I'll just suck it up and have a really wide stance in the front...I'm going to call 4wp to see if they have the Spidertrax in stock today so I can pick them up on my lunch and install tonight.
  9. May 7, 2012 at 11:56 AM
    Pugga
    Massachusetts
    He's no longer with the TW community
  10. May 7, 2012 at 12:06 PM
    XXXX
    sKiP
    05 Prius
    oh he's back :spy:
  11. May 7, 2012 at 12:07 PM
    Pugga
    Massachusetts
    :goingcrazy:
    How do I miss out on these things?!?!
  12. May 7, 2012 at 12:11 PM
    RugbyTaco
    RugbyTaco Rhum.
    Paul
    Sleepy Hollow
    '10 TRD Sport Magnetic Gray
    Wet Okoles, Weathertechs, AFE Pro Dry, Wicked Flow 13", URD MAF, MagLite Mount, 16x8 Procomp 8069, 265/75/16 GY Duratracs, Rear Leaf TSB,AAL, OME 9000s, 884s, S2000 stubby antenna, Leer XR100
    check out bora spacers as well. you can get them in .75" which isnt as bad as 1.5". I had a similar situation however I did grind my calipers but Im still gonna add the .75" spacers just for that extra clearance. There was another site that sold hub-centric 5mm spacers instead of the .25" ones that are lug-centric and could give you vibes. ill see if i can find it
  13. May 7, 2012 at 12:12 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    My rims were about the same without the grinding noise but close maybe .030 (1/32 of an inch) clearance. You have like .005 a sheet of white line paper is .003 or no clearance. Made some .060 spacers (1/16) aluminum sheet on our water jet at work (just od, Clarence hole pattern, and hub dia) got some e/t lug nuts and now have some clearance for my calipers.
    The pic shows a stack of 8.
  14. May 7, 2012 at 12:23 PM
    RugbyTaco
    RugbyTaco Rhum.
    Paul
    Sleepy Hollow
    Check these out. lil bit more $ but might be just what your looking for. another member on here has them, forgot who, said they were good quality
  15. May 7, 2012 at 12:34 PM
    98tacoma27
    Ben
    Not Beech Creek
    East Coast Gear Supply
    Or you can get the 1/4" spacers for $5 a piece from ...which sounds like all you need (OP)
  16. May 7, 2012 at 12:40 PM
    Shep
    Shep Active Member
    Clearwater, FL
    2011 Prerunner DCSB TRD Sport
    Leer Topper, OEM roof racks, OEM Bed divider, Scan Guage II, TRD cold air intake, OME 3" lift 885s and 1/2" spacer with Dakar leaf packs and LR UCAs, NFab steps
  17. May 7, 2012 at 2:16 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Yeah your options are limited.
    Cheapest is to get a thin spacer plates that is thick enough to clear the caliper but still thin enough to keep the wheel hubcentric. Likely 1/8"
    You can get these made to any spec you desire, motorsports tech will build anything you like.
    I searched for a lil for you to see if there any this thin off the self but none that I found. Only ones are 1/4" but that is too thick for you to stay hubcentric.
    You need to check your hub bore as well for the wheels you have to see if you need a hub ring or not to keep them correctly centered.
    You can get bolt on wheel spacers as thin as 3/4", only vendor with this size motorsports tech
    Grinding the caliper is typically a last ditch effort for minimal clearance but you are in need of more than what grinding allows for safely.
  18. May 7, 2012 at 2:35 PM
    The Traveler
    SoCal
    I appreciate everybody's insight. Some great information here but I guess I'm too paranoid to go with any spacer, so instead I placed an order with 4wp to pickup a set of 1.25" thick Spidertrax adapters. I'm going to install them tonight, torque them down, and see how badly they stick out. If it's really noticeable, I'll probably throw a set on the rear as well.
    I'll update tonight if I have time to put them on after work.
  19. May 7, 2012 at 2:38 PM
    Pugga
    Massachusetts
    So... you're paranoid about putting a thin spacer and running extended lug bolts but you're ok with doubling the number of lug nuts, half of which you can't see if they're loose because they're blocked by the wheel? :confused:
  20. May 7, 2012 at 3:16 PM
    lj973gm
    Ohio
    06 DCSB 4wd
    I know I would notice if front wheels stuck out 1.25" and my rears did not.
