Wheel spacers with factory wheels
Discussion in 'Wheels & Tires' started by Pittyboo, Feb 12, 2014.
  1. Feb 12, 2014 at 1:02 PM
    Pittyboo
    Pittyboo [OP] Member
    Victoria, BC
    Black 2014 TRD Double Cab
    Hey all,
    I'm new to this site, and I just got a 2014 tacoma. I like the look of a "wider" look at the wheels. Would spacers do the trick on factory wheels? What are your suggestions?
    Thanks in advance!
  2. Feb 12, 2014 at 1:19 PM
    Walker T
    Walker T OMG! She's NOT wearing her seatbelt!
    Greenville SC
    2025 Celestial Silver TRD Off-Road
    Brand new. Coming soon.
    Yes, spacers work great for spreading out your truck's stance. The only downside is that you MUST use extended thread lug-nuts to attach the spacer to your hub...don't use the ones that are supplied with the spacer unless they are indeed extended thread lug nuts. I got my extended thread lug nuts from Gorilla Automotive.
    You can then use the lug nuts that came with your truck to attach your wheels to the spacer.
    Hope that helps
  3. Feb 12, 2014 at 6:20 PM
    Pittyboo
    Victoria, BC
    Thanks for the help, do you have a link for pictures of tacomas with different spacers width? Not sure yet between 1" to 2"...
  4. Feb 12, 2014 at 7:46 PM
    Qumodo
    Qumodo Kid Hauler Trail Rig
    Evan
    Colorado Springs
    2013 TRD Offroad
    Inno IN-SU roof rack
  5. Feb 12, 2014 at 9:22 PM
    LuckyCharms
    LuckyCharms Knows a little about a lot
    Socal
    '13 PreRunner TRD dclb
    I have had the spidertrax on the front of my truck for the last year and they have been awesome. I beat on them offroading and I tow a 5500 pound trailer. I only bought them because I did a lift and 285's and they are needed to clear the UCA with stock wheels. I just got my new rims today so I don't need them and will be selling them on the cheap... PM me if you want them
    http://toyteclifts.3dcartstores.com/Spidertrax-wheel-spacers-125-inch-Hub-Centric_p_1096.html
    Edit: The lug nuts are fine for this style of spacer. no need for extensions. The type that needs extended lugs or lug nuts are all bad. Don't get those.
    Only pic I really have
  6. Feb 12, 2014 at 9:36 PM
    Riverdog
    Riverdog Well-Known Member
    Collin
    Portland, OR
    '05 Double Cab PreRunner
    I have 1.5" ones on my truck with the stock wheels. I bought them as part of a group buy on here. I'll take a couple pictures tomorrow when there's daylight so you can see how far the tires stick out.
  7. Feb 12, 2014 at 9:44 PM
    Riverdog
    Collin
    Portland, OR
    One more thing. There are spacers and adapters. These are two different things. But it seems most everyone calls both of them spacers. If you go with spacers, you'll need to put longer lugs on your hub like Walker T mentioned. If you go with wheel adapters, you can (most likely) use the lugs that are already there.
    This is a wheel spacer:
    This is a wheel adapter:
  8. Feb 12, 2014 at 10:10 PM
    LuckyCharms
    Socal
    I was under the impression that they are only adapters if they change the lug pattern/size. While thicker spacers use the same style: spacer bolted to hub and wheel bolted to spacer.
  9. Feb 12, 2014 at 10:46 PM
    Riverdog
    Collin
    Portland, OR
    Huh, maybe you're right. Now I'm questioning what I thought was correct... :confused:
  10. Feb 12, 2014 at 10:49 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  11. Feb 13, 2014 at 2:01 PM
    Pittyboo
    Victoria, BC
    I was looking on eBay and came across these, any thoughts?
    http://bit.ly/1hh0q0m
    Fast Wheel Accessories
    6x5.5 or 6.139.7
    2" thick
  12. Feb 13, 2014 at 2:15 PM
    Riverdog
    Collin
    Portland, OR
    Here are a few pictures of my truck with 1.5 inch spacers to show you how much the tires stick out. Stock suspension, stock wheels, Goodyear Duratracs (265/75/16).
    Front
    Rear
    srwilson155 likes this.
  13. Feb 14, 2014 at 5:44 AM
    Walker T
    Greenville SC
    I went with 1-1/2" spacers and they look great. I would strongly recommend the extended thread lug nuts IF your spacer has any distance between the hub face, and the recessed well. The wheel studs on a Tacoma are very short...and any spacer that takes away thread space will need an extended thread lug nut.
    When I put my spacers on initially I could only get three to four turns on a lug nut. Very scary to have your wheels held on by a few threads. But that may just be the brand of spacer I purchased. So check yours out to see if the lug nut well ends up flush with your hub, or elevated from it. If there is space...get extended thread lugs.
    If you need extended thread lugs, call gorilla at 323-585-2852. You want item number 68037, it's a 4-pack of lugs so you need 6 packs of #68037.
