Wheel Spacers
Discussion in 'Wheels & Tires' started by Nick Sells, Oct 24, 2010.
  1. Oct 24, 2010 at 6:30 PM
    Nick Sells
    Nick Sells [OP] Well-Known Member
    Elgin, South Carolina
    2016 TRD Off Road
    Bone Stock
    I saw the thread in the second gen section on lifts but it said if you want to use your stock rims then he recommended the spacers in the thread.My question is are those good for after market also and running the risk of sounding dumb do you put them on the back to I want to say yes but better safe than sorry. Thanks.
  2. Oct 24, 2010 at 6:33 PM
    08pretaco
    08pretaco IG @14burrito
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    what?
    wheel spacers can go on 1 wheel if your heart desires. you only need them if the lift your looking at doesnt fit the criteria for what wheels/tires you have. not all lifts require proper wheel spacing.
  3. Oct 24, 2010 at 6:38 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    15 Lariat Sport 5.0L
    3rd gen forum caused me to get a Ford
    what lift and tires are you looking at running w/ stock wheels? also, the wheel spacers are more used for stock wheels w/ 285s or wider tires so they dont run the UCAs.
  4. Oct 24, 2010 at 6:45 PM
    Nick Sells
    2016 TRD Off Road
    Bone Stock
    I was planning on getting the toytec ultimate lift and running some 285's on aftermarket 16 wheels
  5. Oct 24, 2010 at 6:51 PM
    08pretaco
    Oliver
    az
    so if your getting those with 16's if the tire width is 8" get 4.5" bs and if the wheel width is 9" get 4.5 bs with -12mm offset :)
  6. Oct 24, 2010 at 6:57 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    OP: No offense but most of the questions you ask can be answered with a simple search. This is the 23rd thread you have created this month! At least you stopped posting in all CAPS though....
  7. Oct 24, 2010 at 7:02 PM
    jhodge83
    SC
    the guy below has it...if you get an aftermarket wheel w/ a 4.5" BS, then there is no need for wheel spacers
