Wheel Spacers
Discussion in '5 Lug' started by 05RedTaco, May 6, 2011.
  1. May 6, 2011 at 8:00 AM
    05RedTaco
    05RedTaco [OP] Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    I know most of you here are against wheel spacers and some of you run wheel spacers without issues... So... Right now I am running Fat Bob's kit with stock wheels and 31x10.5x15 tires. The front tires rub at full lock. Now I wont be able to get new wheels anytime soon, so... I was thinking of picking up set of wheel spacers and space out the front a little... If i like the spacers, I will space the back as well, I would like the wheels to stick out a little, now they are too flush with the fenders. The wheel spacers come in many thicknesses... 5mm, 8mm 12.5mm (1/2"), 1", 2"...
    I am thinking of picking up set of 8mm or 12.5mm, the 1" and 2" are too expensive. I would like to stay away from changing lug nuts as well and still be safe.
    Your thoughts?
  2. May 6, 2011 at 8:33 AM
    disc0monkey
    disc0monkey All right. I believe ya. But my Tommy Gun don't!
    First time i saw ur truck I was like needs at least spacers. I worked at a custom performance shop and we did a few widebodies and whenthe customer wanted to keep stock look with their wheels we would fit the car with a quality spacer. Just wouldn't hammer the truck going offroad
  3. May 6, 2011 at 8:34 AM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    It would be unsafe with wheel spacers and using the stock lug nuts IMO. How much lift do you have and what are you rubbing on? I find it hard to believe you are rubbing with 31x10.5" tires.
    Edit: just saw in your profile you have a 5 lug.
  4. May 6, 2011 at 9:10 AM
    05RedTaco
    Tony
    Scottsdale
    Ya 5lug... It rubs only at full lock ...
    My truck is 98% of the time street work truck...
  5. May 7, 2011 at 12:44 AM
    LBCdan
    LBCdan I got tiger blood.. WINNING
    Dan
    Long Beach , CA
    2012 MGM DCSB TRD SPORT
    Pioneer 4000NEX , grab handle GPS mount, Bakflip tonneau, OME 885, Bilstein 5100s, Wheelers 1.5" AAL
    Have you done the black box mod? That helped with the rubbing issues on my 245.75.16s. El rubbing es no mas. :D I am running 1/2" spacers because my enduros do not clear the 09 calipers. FYI.
  6. May 7, 2011 at 7:28 AM
    disc0monkey
    Wait your running half inch spacers? I didn't get the enduros because they looked to have stuck out to much for me on your truck. Could u have ground the caliper? I ended up getting a 5" backspace on 16x8. I think I can still change the order
  7. May 7, 2011 at 11:56 AM
    LBCdan
    Dan
    Long Beach , CA
    Yep. Mine have 4.5" backspacing and I have a 1/2" spacer. It rubbed the caliper without the spacer. I didnt grind the calipers at all and the tires only stick out 1/2" - 1". Ill take a picture for you . I like how it looks..
  8. May 7, 2011 at 12:00 PM
    disc0monkey
    I like it too I was just in southern ca two weeks ago and yeah if I lived there it would he fine but don't wanna get my balls busted by the fuzz here in jerz
  9. May 7, 2011 at 12:15 PM
    LBCdan
    Dan
    Long Beach , CA
    Oh. I didnt realize you can get in trouble with the 5-0 for having your wheels stick out a little. Sucks for you! haha:D
  10. May 7, 2011 at 2:56 PM
    05RedTaco
    Tony
    Scottsdale
    Do you run stock wheel studs? How many turns were u able to turn the wheel lugs with the spacers installed?
  11. May 7, 2011 at 4:02 PM
    LBCdan
    Dan
    Long Beach , CA
    Yeah. Stock studs. The lug nuts are bulge acorn et (extra thread). The get me 9 turns with the spacers.
  12. May 7, 2011 at 4:06 PM
    alexmxman185
    alexmxman185 Keepin' it dirty in Texas
    Alex
    Waco, Texas
    08 toyota tacoma 2.7 4 cly 5 lug
    Black grille guard with mounted kc road lights, 31x9.5x15 AT on stock rims. My future mod list: new white front bumper, Fat Bobs 2.75 spacer lift with rear AAL, american racing Flat Black Rims, 32x11.5x15 BFG A/T, satoshi grille with road lights mounted behind it, 8000k HID for all lights, 1'' Body Lift, new window tint, blacked out headlights and taillights, custom hood scoop, weather tech floor liners, LED dash cluster replacement, Front bilstein shocks, 40 series flowmaster, paint all my badges black.
    are you totally against buying new rims? with a negative offset it'll push them out and away and your truck would look a little better with after market rims...
  13. May 7, 2011 at 4:37 PM
    disc0monkey
    Only spacer I used was the ones that had the lugs on the spacer
  14. May 8, 2011 at 7:56 AM
    05RedTaco
    Tony
    Scottsdale
    I know, money is an issue. I would rather invest in re-gearing the truck. 2.7L with 3.33 gears and 31x10.5x15 tires sucks ass while accelerating!
  15. May 9, 2011 at 4:31 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I have 1.5" Spacers on the rear... they're the ones that have new studs in them though. They haven't had any issues so far.
  16. May 12, 2011 at 7:54 AM
    05RedTaco
    Tony
    Scottsdale
  17. May 12, 2011 at 7:56 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    spacers will make you rub worse
  18. May 12, 2011 at 7:59 AM
    05RedTaco
    Tony
    Scottsdale
    How so? To clarify... I am only rubbing at full lock and it rubs NOT on the wheel well it rubs on the front sway bar...
  19. May 14, 2011 at 8:57 PM
    05RedTaco
    Tony
    Scottsdale
    Exactly what size thread pitch bulge acorn lug nuts you have?
  20. May 14, 2011 at 9:06 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    sounds like 12x1.5 ET (extended thread)
