Wheel Spacers?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 06midnight, Mar 25, 2014.
  1. Mar 25, 2014 at 3:56 AM
    06midnight
    06midnight [OP] WORK HARD - PLAY HARD
    Montgomeryville, PA
    '06 Taco PreRunner TRD
    3" Spacer/Block Lift, Billet Grill with Painted Surround, Clear Headlights, LED Tails, Double Din Nav Radio, LED Interior Lights
    Guys,
    just a quick question for those who are running the 285's with stock 16" wheels. With a 3" lift, are wheel spacers necessary? Understanding there may or will be trimming. Stick with 265's or move to 285's? Issues with 285's on stock 16" wheels? Opinions?
    I'm going to get tires this weekend so I need to know if I should get the spacers as well.
    Thanks guys
  2. Mar 25, 2014 at 4:00 AM
    biglinc
    biglinc Well-Known Member
    linc
    maine
    07 tacoma
    they will rub the upper control arms,get spacers.
  3. Mar 25, 2014 at 6:25 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    x2. Look into 1.25" hub centric spacers like spidertrax along with some plastic trimming.
  4. Mar 25, 2014 at 9:01 AM
    06midnight
    Montgomeryville, PA
    Thanks. That's what I was expecting but wanted to make sure.
  5. Mar 25, 2014 at 10:59 AM
    FrankG9702
    FrankG9702 Active Member
    Frank
    Alabama
    2013 4x4 SR5
    3" Toytec Suspension Lift
    They will definately rub; I have the 3" Toytec lift w/1.25" wheel spacers all around and my rubbing problem went away with my 285/75R16's. No trimming required. I would highly recommend getting wheel spacers for all 4 wheels (Spidertrax comes in sets of 2), looks funky with just the front ones having spacers.
  6. Mar 25, 2014 at 1:57 PM
    06midnight
    Montgomeryville, PA
    Yeah, I would get 4 all around. If you're wrapping these on stock 16" wheels, and using 1.25 spacers, how far out do the wheels stick from the fender? PA is bad when it comes to tires sticking out far! Pics?
  7. Mar 25, 2014 at 2:25 PM
    FrankG9702
    Frank
    Alabama
    2013 4x4 SR5
    It's not very far, perhaps 1 1/2" max near the bottoms of the fenders and almost flush at the top. Will have to take some pics when I get home.
    And you will definately have to remove your front mud flaps.
  8. Mar 25, 2014 at 5:26 PM
    06midnight
    Montgomeryville, PA
    Cool, thanks.
  9. Mar 28, 2014 at 9:20 AM
    BAMATACO12
    BAMATACO12 Well-Known Member
    Birmingham, Alabama
    02 Tacoma 4WD TRD
    2.5' Fabtech Suspension lift. 285/75/16 Cooper STT's New headlights Surefire mount with Quick Fist Shrockworks bumper-3 wks out on delivery Light Force 240 Blitz arriving today
    I am looking into spacers as well. I'm running 285/75/16 Cooper STT's with a 2.5 inch lift. I was/am also concerned with the amount of tire that comes out from the fender. I'm thinking the Spidertrax 1.25" will work to correct the rubbing issues I have with my uca's and frame. Here is my truck before spacers.
  10. Mar 30, 2014 at 9:58 AM
    jtacoma1
    jtacoma1 Active Member
    J
    South Orange County, CA
    '11 Tacoma DC 4x4
    If you do 285's with 17" wheels and the 2.5" lift do you still need the spacers? Are the spacers only necessary with the 16" wheels?
    Also, if the rims already had 4.5-4.75" backspacing would you need the spacers still?
  11. Mar 30, 2014 at 2:51 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I needed spacers with my 265's on 17-inch rims; so, yes, you will need them with 285's. And if I recall correctly, the oem wheel studs were on the short side; so, I installed longer studs that ended up protruding about 3/8 from the wheel adapter. Lucky for me, my oem wheels have holes to 'swallow' the tips of the studs. http://www.wheeladapter.com/wheel_studs.php
