Wheel Spacers?
Discussion in '1st Gen. Tacomas (1995-2004)' started by sypher651, Sep 7, 2016.
  1. Sep 7, 2016 at 5:52 PM
    sypher651
    sypher651 [OP] Nothin' but trail lovin'!!
    Groveland, California
    1996 Tacoma 4x4 3rz
    Looking into giving my tacoma a wider look. I am not knowledgeable on spacers by any means, can someone school me. and also if you are selling spacers please by all means message me.
  2. Sep 7, 2016 at 5:54 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Look into either Bora or spidertrax spacers. Can't go wrong with either of those. Just be sure to check the torque of them every once in awhile and you'll be good!
  3. Sep 7, 2016 at 5:58 PM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    If your going that route only get high quality spacers/brands. Don't want to skimp on something like this. I recommend Bora's or spydertrax. Would not go past anything bigger than 1.25"-1.5" as you will really put a ton of stress on other components. That said the best and proper way to go is get different wheels with the correct backspacing for what your needs are but spacers will do the trick as well.
  4. Sep 7, 2016 at 6:03 PM
    sypher651
    1996 Tacoma 4x4 3rz
    So if I go with the 1.5" spacer is there a way to calculate how big I can go tire wise on the stock wheel without getting rub? I am looking at the SpiderTrax
  5. Sep 7, 2016 at 6:05 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Depends what the backspacing is on your current wheels! With spacers, the goal is to get the tire off of the UCA, so it all depends. With second gens, it's a 1.25" spacer to run 285s
  6. Sep 7, 2016 at 6:06 PM
    sypher651
    1996 Tacoma 4x4 3rz
    my truck kinda turned into a work/pavement prowler/minor trail camping. But if the stress would still be too much for say, fire road driving, I may take your word for buying new wheels.
  7. Sep 7, 2016 at 6:07 PM
    FirstGen Jer
    Jeromey
    285/75/16 or 33" depending on your wheel b.s. and lift If you do not off road at all . If you do, there will be minor rubbing on the pinch weld in the front and mud flaps so you would need to remove those and bang the pinch weld down some.
  8. Sep 7, 2016 at 6:09 PM
    FirstGen Jer
    Jeromey
    Naw you will be fine...what lift do you have because that is a factor as well.
  9. Sep 7, 2016 at 6:11 PM
    t(u)rdtaconator
    t(u)rdtaconator Well-Known Member
    Regretsville
    2016 DCLB Sport 4x4 SSM Conv/Tec/JBL
    Icon Stage 2, Dakars, bunch of other stupid $#!+...
    Don't forget to put down a coat of anti-seize when mounting to the rotor/drum. I had the spidertrax on my new tacoma for less than a month and those things were a bitch to get off the rear drums.
  10. Sep 7, 2016 at 6:18 PM
    sypher651
    1996 Tacoma 4x4 3rz
    I don't have any lift. I like the lower look. But now that I am looking at wheels.... I am looking to spend around 1200 on wheels and tires. Keep my current set for winter wheels and tires. Any suggestions on 17's
  11. Sep 7, 2016 at 6:20 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Not trying to be a jerk, just doesn't make sense to me. How can you fit 285s without a lift, just by using wheel spacers? Wouldn't it be 265s still?
  12. Sep 7, 2016 at 6:20 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    If you order from discounttiredirect.com they ship for free, and if you get wheels and tires they mount and balance them for free
    DustStorm4x4 likes this.
  13. Sep 7, 2016 at 6:20 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yep, I believe you're right. We didn't realize he didn't have a lift.
  14. Sep 7, 2016 at 6:22 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    Ok I just wanted to confirm. Thanks.
  15. Sep 7, 2016 at 6:25 PM
    FirstGen Jer
    Jeromey
    You can't, I was assuming since he asked how big a tire can he fit he had a lift too. So he is looking at a 31" tire I believe if he is still stock
  16. Sep 7, 2016 at 6:26 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    Gotcha. I just got confused for a moment. All is well.
    FirstGen Jer[QUOTED] likes this.
  17. Sep 7, 2016 at 6:37 PM
    sypher651
    1996 Tacoma 4x4 3rz
    Okay so I think I am going to go with a whole new set of wheels... keep the old ones for snow tires. So I am probably going to go with 17" x 9" and when it comes to offset... I kinda need a schooling on that also... so a negative offset is going to give it a sunken in look?
  18. Sep 7, 2016 at 6:41 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    https://www.customwheeloffset.com/tire-wheel-backspacing-offset-calculators
    Play around with this. Enter the width and offset and it'll calculate the offset.
    Let's say for example purposes the backspacing on your current wheels is 5", and they're 7" wide wheels. That means there's 2" of wheel sticking out.
    If you have backspacing of 4" on 7" wide wheels, they stick out 3", or 1" further than stock.
    FirstGen Jer likes this.
  19. Sep 7, 2016 at 6:59 PM
    sypher651
    1996 Tacoma 4x4 3rz
    So I am lost... sorry. How do I find the backspacing? My current wheels are 235/75/15 at 7"wide.
    I would like to go to either 17's or even 18's if I can.
  20. Sep 7, 2016 at 7:03 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    No worries. This shit took me forever to understand it. You need to figure out the offset or the backspacing on your current wheels. Do some searching around here.
