Wheel spacers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jdawg887, May 19, 2017.
  1. May 19, 2017 at 5:09 PM
    Jdawg887
    Jdawg887 [OP] Member
    Jacob
    Brunswick ga
    Black 2010 trd sport dclb
    3" rough country lift kit Rough country bull bar 20" rough country light bar Dual series 50 flow masters
    I have a 2010 trd sport dclb with a 3" lift. Is it possible to run 33/12.50 r17s without wheel spacers?
  2. May 19, 2017 at 5:18 PM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Likely yes but what wheel is it mounted on?
    Also, depends on having a knowledgeable alignment tech who recognizes how to center a tire in the wheel well yet still align it to a good functional alignment...which, by the way, doesn't mean it'll be with the Manufacturer's specifications.
    Alexely999 likes this.
  3. May 19, 2017 at 5:26 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Like he is saying ^
    If you are on a stock wheel you should be OK but if you have a aftermarket wheels you probably don't want a spacer as it might push it out to far and you will have issues rubbing your cab mounts
  4. May 19, 2017 at 5:28 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Depends on what wheels and back spacing. They will probably rub the UCA on stock wheels. 12.5" wides are wider than 285s. And some people rub the UCA with those.
  5. May 19, 2017 at 5:30 PM
    bullaculla
    Da big big island!
    These are 285/75/16 MTRs next to 37x12.5x17 MTRs.
    Tatts521 likes this.
  6. May 19, 2017 at 5:33 PM
    Jdawg887
    Jacob
    Brunswick ga
    the wheels I ordered have 0 offset
  7. May 19, 2017 at 5:40 PM
    Pigpen
    Dan
    Northwest Montana
    What's the back spacing? You'll never be able to run a 12.5 on a stock BS wheel without spacers.
  8. May 19, 2017 at 5:57 PM
    Jdawg887
    Jacob
    Brunswick ga
    The back spacing is 5"
  9. May 19, 2017 at 6:04 PM
    bullaculla
    Da big big island!
    I'm gonna guess that you will rub the UCA.
  10. May 19, 2017 at 9:10 PM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    This!
    With a 5" backspacing I'm pretty sure you'd be close with the 285's.
    What kind of lift do you have? Did you upgrade your UCA?
  11. May 19, 2017 at 9:15 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    You're going to rub all kinds of shit. I rubbed with 265/70's with the same offset and backspace. Wheel spacers will make it worse.
  12. May 20, 2017 at 10:34 AM
    Darkgoatracer
    Darkgoatracer Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
    I run 33 12.50's on my truck with only minor rubagge
