Wheel spacers
Discussion in '1st Gen. Tacomas (1995-2004)' started by Willstutz7, Jul 25, 2017.
  1. Jul 25, 2017 at 7:45 PM
    Willstutz7
    Willstutz7 [OP] Self-proclaimed, unjustified expert
    Will
    2003 TRD Off-road Extra cab V6 Prerunner
    3” allpro leaf springs; Bilstein 5100 shocks all around; thrush welded muffler back system; deck plate mod; 1.5” wheel spacers; rear led bumper light pods
    I wanted to get some spacers for the ole taco and I don't know what size to get. I've heard the 1 1/4 are great but I want to try to get a more aggressive stance. I'm running 265/75 tires right now. If anyone has pictures of 1 1/4 spacers and 2" spacers that would be much appreciated. Also would it cause rubbing?
  2. Jul 25, 2017 at 8:07 PM
    2BeersPlease
    2BeersPlease Well-Known Member
    Don't think you really need them with that size tire.
  3. Jul 25, 2017 at 8:12 PM
    2BeersPlease
    I have 1.5" spacers, but I'm running a 285 on 7" wide rim. If I had an 8" wide rim with maybe 4" backspace, I wouldn't need the spacers.
    ChadsPride likes this.
  4. Jul 25, 2017 at 8:16 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    1.25" spacers with 265/75r16 tires is perfect, the tires will stick out just enough past the fender flares and it won't rub too bad on the pinch weld. You'll have to do a little trimming on the plastic wheel well liner but nothing major. 2" spacers is too much, you'll rub like crazy and it'll look funny.
  5. Jul 25, 2017 at 8:32 PM
    2BeersPlease
    I think you have more than rubbing to worry about. That tire is the same width as the stock 265/70. Why would you want to move a stock width wheel out another 1.25"? For looks?
    It's your truck. You're free to do what you want even if it's ill-advised.
  6. Jul 25, 2017 at 8:40 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Tire width is the same, but 265/75 is an inch larger in diameter. With stock wheels (4.5" BS) you'll rub on the frame at full lock/compression pretty bad if you don't have spacers. You could probably get away with less than 1.25" though, maybe 1" would work.
  7. Jul 25, 2017 at 10:38 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Go as small as possible with the spacers. 1-1.25" should be good enough. Any more and the truck will handle differently and this is coming from someone that's had no spacers, 1.25" with stock wheels, 1.25" with wheels with 3.5" back spacing, wheels with 3.5" and no spacers, a long travel kit with 1.25" spacers and w/o spacers, and 2" spacers up front. I like the added road feel of 1.25" spacers on stock wheels / no lt kit. 2" isn't the best feel I've experienced and I just did it to match a wider rear axle in the rear until I could get the front Long travel.
    tcjacado likes this.
  8. Jul 26, 2017 at 12:03 PM
    2BeersPlease
    I didn't realize stock 265/70s were that close to the frame at full lock that 1/2" more tire would make the tires rub. My 285s still rub a little with the 1.5" spacers. The steel wheels I have are +32 offset, which is quite a bit more than my factory alloys at +15. I guess these are the issues you run into with 2nd gen rims on a 1st gen truck.
    1.75" spacers would effectively give me about 3.5" backspace and likely eliminate the rubbing all together, but I don't want to go that wide. A better solution is to get 8" rims with the appropriate offset.
    Dalandser likes this.
