Wheel spacers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bravoboi123, Nov 14, 2017.
  1. Nov 14, 2017 at 4:13 PM
    Bravoboi123
    Bravoboi123 [OP] Member
    Sean
    2014 xspx v6 4.0 4x4
    3 inch lift with 295/75/16 nitto a/t
    Ok guys what is the best wheel spacer on the market for the price and safety. Thanks
  2. Nov 14, 2017 at 4:38 PM
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
    Welcome to tacomaworld. :wave:
    I find most anything Im looking for by using Google...then typing..
    tacomaworld.com best wheel spacers.
    You'll find lots of good info..
    :hattip:Enjoy
    freddy2923 and Whitetrash like this.
  3. Nov 14, 2017 at 4:39 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    End Thread/
    ChemDawg likes this.
  4. Nov 14, 2017 at 4:44 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Do you actually need wheel spacers? Are you trying to fix a clearance issue or do you just want to randomly push out your wheels farther? What size are you looking for?
    Spidertrax are popular. They're 1.25" thick.
  5. Nov 14, 2017 at 8:32 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    im a fan of Bora spacers, and you can get them in any size you want.
  6. Nov 14, 2017 at 8:42 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    HUB CENTRIC!!!!! DO NOT GET CHEAP LUG CENTRIC!
  7. Nov 15, 2017 at 6:26 AM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    Ebay is a nonono
    Spider trax has 1.25 or 1.5
    Bora you can pick whatever you want.
    Personally anything over 1.5 with a large wheel offset means you will be eating through wheel Bearings so be careful of that.
    HUB CENTRIC ONLY
  8. Nov 15, 2017 at 8:11 PM
    dino41
    dino41 Well-Known Member
    San Diego, California
    2015 Sky Silver Crew Cab V6 SR5 Prerunner
    I took my truck in to my tire shop today to have my wheels rotated and brought my 1.5" hub centric spacers with me in hopes of having them installed while the wheels were off. Apparently they don't advice having spacers installed and they talked me out of putting them on. I value their opinion and expertise. They told me that these will put unwarranted stress and wear on my front suspension and I would experience shacking at high speed. I was also told that in some cases, they can actually break apart or the studs snap off and the wheel coming off while traveling. The example used made sense to me. I was told to imagine an axle with two wheels and standing on the center. The further the wheels are apart the greater the center pressure becomes eventually causing the axle to bend. What is your experience with spacers? Should I heed their advice and warning or just go ahead and install them on?
  9. Nov 15, 2017 at 9:17 PM
    MK_Ultra
    MK_Ultra Well-Known Member
    2012 basic DCLB
    not much
    coming from the sport car world and having only owned a tacoma 2 years. I would never use them on any car unless you love replacing wheel bearings. I can't imagine the extra stress and weight would help on the tacoma.
    Just get the right wheels you want with that offset to give that "Push out" you're going for.
  10. Nov 15, 2017 at 9:27 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Over 60k on my 2011 with spacers, approaching 70k on my 2015 with spacers. No problems what so ever, I basically forget about them
    freddy2923 likes this.
  11. Nov 16, 2017 at 7:20 AM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    Farther out the wheels are the more stress goes on suspension and steering components ON the axle, not the axle itself. One big thing you will always see will be wheel bearings because well, they are bearings and are not engineered to have that extra force on them at all times a 1.5 spacer and wheels with a far out offset would cause. Shaking at high speed usually will not happen with Bora or spidertraxx spacers. As long as its centered on the hub and the mating surfaces are clean with all lug nuts torqued down you shouldn't have an issue. A lot of members here have somewhat close to stock offset wheels and use 1.25" spacers to get that clearance they need in the wheel wells when flexed out on trails. Bora and spidertraxx are quite high quality which is why you pay so much for 4 of them, i have no memory of seeing any threads on snapping studs off those. Lug centric ebay spacers (or some lug centrics in general) on the other hand will snap your lugs right off, that would be the case of pushing the wheels out far on heavy tires making the week point the stock studs on the vehicles hub.
  12. Nov 16, 2017 at 10:24 AM
    BigBiscuit
    BigBiscuit Well-Known Member
    Mass.
    2010 TRD Sport DCSB MGM
    My son in law put a 6" lift on his F150 and 35" tires. I don't know who figured out the wheel offset for him, but when it was all said and done, he required 2" spacers to clear with no rub. 8 months later, he needs to replace the left front wheel bearing. I warned him of the possibility, but he didn't want to listen. I don't believe his problem is strictly due to the spacers though. I think it's a combination of the spacers, wheel and tire combo. His tires extend past the wheel wells by at least 10".
  13. Nov 16, 2017 at 10:25 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Can anyone search?
    Millions of threads on this..
  14. Nov 16, 2017 at 2:51 PM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    THERE IS A SEARCH OPTION?!?!?!?!!? :p
  15. Nov 16, 2017 at 5:52 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    That's a nice looking dog in your profile pic!
