wheel spacers
Discussion in 'Technical Chat' started by life long tacoma, Jul 17, 2019.
  1. Jul 17, 2019 at 12:06 PM
    life long tacoma
    life long tacoma [OP] New Member
    2018 tacoma
    toyota
    I have a 2018 trd sport all stock what size of wheel spacer can i use and not rub.
  2. Jul 22, 2019 at 3:20 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    This question doesnt make sense since you state that your truck is all stock, they dont rub when everything is stock unless something youve damaged something. Is something rubbing with your stock setup? Stock would be the same size tires as from the factory, different knobby tires sure but not larger size. Are you planning on getting oversized wheels? that would cause it to rub if you go big enough, if you are planning on going oversized tires what size were you planning on?
    Taylorbarton1 likes this.
