Wheel spacers
Discussion in 'Wheels & Tires' started by lennythetaco, Jan 4, 2010.
  1. Jan 4, 2010 at 5:22 PM
    lennythetaco
    lennythetaco [OP] Active Member
    If i need to put wheel spacers on my tires so they dont rub the UCA would i only put them up front or do i also put them in the back
  2. Jan 4, 2010 at 5:36 PM
    KMN-BLU
    KMN-BLU less work/more play
    Destin, Fl
    2018 Tacoma TRD PRO
    Put them all the way around for a uniform look. Otherwise you get that offroad flat track look with a wide front and skinny rear. It makes a difference
  3. Jan 4, 2010 at 5:37 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yeah..Don't HAVE to put them all the way around..but you'll see it.
  4. Jan 4, 2010 at 7:30 PM
    airsoft_warrior
    airsoft_warrior Batman
    Zack
    Edgewater, Maryland
    2015 Tacoma DCLB Limited
    TRD Performance Exhaust
    What size spacers if I am putting on 285's so they dont rub the stock UCA's?
  5. Jan 4, 2010 at 7:31 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    What kind of tires are you running?
  6. Jan 4, 2010 at 7:34 PM
    revhappyleon
    revhappyleon Well-Known Member
    Manny
    Tampa near macdill
    07 Prerunner V6 6-speed(custom dual exhaust)
    dual exhaust, foglight anytime, satoshi, chlm, aux backup lights and electric fan conversion
    1.25" from spidertrax seems to be the only real option since i wouldn't try an offbrand part on something so crucial
  7. Jan 4, 2010 at 7:36 PM
    KMN-BLU
    Destin, Fl
    2018 Tacoma TRD PRO
    Im not sure who you are asking for the tires. The original OP or me.
    But I am running BFG KM2 285s
    I have 1 1/4 inch spacers but I have Camburg Uniball UCAs
  8. Jan 4, 2010 at 7:39 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    I was asking you. Thanks. I want 285's but not sure if they will rub on the stock UCA's. Looking at spacers to make sure. I know nothing about spacers.
  9. Jan 4, 2010 at 7:44 PM
    KMN-BLU
    Destin, Fl
    2018 Tacoma TRD PRO
    Well, one other thing you have to consider is the offset of whatever wheel you will be using. The deeper the offset the more it pushes that wheel out from your truck.
    Why are you sticking with stock UCAs? Are you installing any type of lift?
    Without any lift you may have a tough time stuffing that 285 in that wheelwell without a lot of cutting.
  10. Jan 4, 2010 at 7:50 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    I have bilstein 5100 on there at 2.5" with stock rugged edition wheels. I dont know that their offset is. I am sticking with stock UCA's at the moment because I dont have the funds to upgrade them. What is the benefit to upgrading them anyway. I have never asked.
  11. Jan 4, 2010 at 7:52 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    ^^^ Alignment will benefit.
  12. Jan 4, 2010 at 7:54 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    I noticed yesterday that the tires do tilt in a little.
  13. Jan 4, 2010 at 7:55 PM
    KMN-BLU
    Destin, Fl
    2018 Tacoma TRD PRO
    I started out with a 3" lift and when i put 285s on there i ended up cutting alot to get it to stop rubbing. I mean I cut a big chunk off from that frame mount point. I ended up raising it up another inch as well for clearance.
    However, I have heard of others putting on 285s and not having to trim or cut out anything.
    I cannot answer your stock UCA question about tire rub. However, I suspect it will rub with the stock parts.
  14. Jan 4, 2010 at 7:55 PM
    Jason'sLawnCare
    Did you get it aligned yet? Did they have any problems?
  15. Jan 4, 2010 at 7:57 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    I got it aligned, but I went to SEARS (Wont do that again) They gave me a printout of the alignment but couldnt explain it to me. I should go back and say that it isnt aligned and get them to realign it for free.
  16. Jan 4, 2010 at 8:13 PM
    05trdsport
    05trdsport Well-Known Member
    Calgary AB CAN
    2005 TRD Sport Silver
    K&N cold air intake, Aroturbine exhaust OME 885's on OME Nitrochargers, Total Chaos UCA, 1-1/4" wheel spacers, TRD sport wheels coated flat black, dick cepek AT 285/70/17, Alcan AAL/OME rear struts, Blacked out front valance, bhlm headlights, nav/ipod eclipse headunit. URD maf calibrator with map option. Supercharger in the works.
    the whole spidertrax is better than all other spacers is the biggest joke ever. you can buy regular spacers (yes you can get hubcentric as well) from your local 4x4 shop or have a machine shop make them for you. the only difference between spidertrax and no name spacers is the color blue... i have had my no-name spacers on for over a year and have had no issues whatsoever with them. i went with the 1.25". dont waste your money on spidertrax spacers.
  17. Jan 5, 2010 at 12:21 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Well I haven't heard of anyones wheels falling off while running Spidertrax :p I have with the other brands :laugh:
  18. Jan 5, 2010 at 12:29 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
  19. Jan 5, 2010 at 9:12 PM
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    What about the small 3/16" universal spacers at pepboys. Are these ok to use as long as you can get the lug nuts on good?
  20. Jan 10, 2010 at 9:19 PM
    04tacoma4x4
    04tacoma4x4 Member
    Kirby
    West tennessee
    04 red extra cab 4x4
    3 inch pro comp lift 2 inch wheel spacers k&n cold air touch screen double din
    What do yall think of a 3 inch lift the lift consist of 3 inch strut spacer and a rear add a leaf I just installed and also installed 2" wheel spacer. I had it aligned and I just don't know what to think I am running a 275 70 16 and I just wonder what fellow Tacoma owners think good or bad idea
