Wheel specs for 3" lift.
Discussion in 'Wheels & Tires' started by Eesh, Jun 30, 2012.
  1. Jun 30, 2012 at 5:08 PM
    Eesh
    Eesh [OP] Well-Known Member
    Canada
    2025 Tacoma Limited
    I'm just about to put my 3" OME lift on my truck. I want to order some wheels. Will 4.5" back spacing work? What is the 05-11 trd sport stock wheel back spacing? Am I going to need Wheel spacers? I'm just going with 265 70 17 Duratracs.
    I plan on going with these Robby Gordon wheels 17x 8
  2. Jun 30, 2012 at 5:09 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I believe the Sport alloys are 5" BS
  3. Jun 30, 2012 at 5:12 PM
    OZ-T
    Peter North
    British Columbia
  4. Jun 30, 2012 at 5:14 PM
    Eesh
    Canada
    2025 Tacoma Limited
    Am I going to need wheel spacers???
  5. Jun 30, 2012 at 5:17 PM
    OZ-T
    Peter North
    British Columbia
    They are going to stick out 1" farther than on the Sport alloys . They may rub the mudflaps if you still have them on .
  6. Jun 30, 2012 at 7:55 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    If you run spacers in conjunction with the RG's you'll rub, bad.
  7. Aug 14, 2012 at 3:46 PM
    Eesh
    Canada
    2025 Tacoma Limited
    Even though my tires are 265s????
  8. Aug 14, 2012 at 7:07 PM
    TexasTacoma37
    Yes. The spacers will make the effective backspacing around 3.25", which pushes the wheels out much too far.
  9. Aug 15, 2012 at 4:40 PM
    JdMeF9SiR2
    JdMeF9SiR2 FN Wheels
    Corona, CA
    05 Tundra 06 Tacoma 14 FJ Cruiser 19 Tundra
    17x8" wheels with 4.5" back spacing (0mm offset) will work perfectly without the need for spacers. You should not have any rubbing, even with 265/70R17, once you are lifted. Even without a lift the rubbing, if any, would be extremely minimal.
  10. Aug 15, 2012 at 4:46 PM
    Eesh
    Canada
    2025 Tacoma Limited
    GOD I HOPE YOUR RIGHT. I have the Wheel adapters just in-case they don't clear the Break calipers.
    Or actually...... I think I do need the wheel adaptores... the center bore on the Wheels is[FONT=verdana,geneva,lucida,lucida grande,arial,helvetica,sans-serif] 89mm. And my trucks Hub bore is 106 mm[/FONT] <----- (does that even matter)???????
  11. Aug 16, 2012 at 1:03 PM
    JdMeF9SiR2
    Corona, CA
    Lower back spacing / offset does not automatically equate to brake clearance. You'll still need to check brake clearance.
    If the wheels have an 89mm center bore you will need either have the wheels opened up to 106.1 (make sure that the wheels are inspected first to be sure that it is safe to open the center bore up), or you'll need to run a spacer that is at least as thick as the height of the hub on your truck, otherwise the wheels will not fit over the hub. Once you run a spacer that size (1.25"+), all bets are off regarding all previous comments about fender clearance. You'll be effectively lowering the back spacing to around 3.25", which is quite aggressive.
