Wheel specs to fit new lift and desired tire size
Discussion in 'Wheels & Tires' started by tacodan89, Mar 29, 2018.
  1. Mar 29, 2018 at 5:40 PM
    tacodan89
    tacodan89 [OP] New Member
    Dan
    2015 Tacoma TRD Sport Double Cab
    I'll start off apologizing if this is covered in another thread but I couldn't find it.
    I have a 2015 TRD Sport Double cab with 5ft bed. I have ordered an All-pro Lola Suspension Kit with Standard leafs and FOX IFP 2.0 rear shocks. Should give about 3 inches of lift.
    I want to put 285/70/17 tires on it but am not sure what size rims I should use as far as backspacing/offset and width for best performance and rubbing concerns.
    I appreciate the help in advance.
  2. Mar 29, 2018 at 5:49 PM
    tcjacado
    tcjacado Well-Known Member
    0 back spacing
    4.5 on offset
    17 x 8 or 17 x 8.5
    You will need to do some trimming also on the wheel well.
    Bluegrass Taco likes this.
  3. Mar 29, 2018 at 5:54 PM
    tacodan89
    Dan
    Awesome, thanks for the quick response!
    tcjacado likes this.
  4. Apr 5, 2018 at 6:36 PM
    tacodan89
    Dan
    ITs been difficult to find wheels I like with those specs. Here are a couple of specs that are close. Will they work?
    17x8.5
    +7mm offset
    5 in backspacing
    or
    17x8.5
    -6 mm offset
    4.5 in backspacing
