Wheel Specs
Discussion in 'Wheels & Tires' started by replica9000, Mar 18, 2009.
  1. Feb 8, 2016 at 8:16 AM
    #281
    k3v11n
    k3v11n Yeah? No!
    Oahu, Hawaii
    2015 SR PreRunner Oahu Edition
    PlastiDip
    Thanks. So I'm assuming with a 3/4 - 1 inch wheel spacer, I'd be able to run 285/75/16 with very minimum rubbing?
  2. Feb 8, 2016 at 8:33 AM
    #282
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    With a spacer you will be fine
    k3v11n[QUOTED] likes this.
  3. Feb 8, 2016 at 12:42 PM
    #283
    MK ULTRA
    MK ULTRA Well-Known Member
    JIM
    Huntsville Ala
    4X4
    1.25" thick spacers will work with standard lug nuts. And they should be hubcentric.
  4. Feb 9, 2016 at 12:31 AM
    #284
    jaydonguyen
    jaydonguyen s2JAY
    jay
    Long Beach
    2015 toyota tacoma 4x4 off road.
    pro grill bed mat weather tech visors weather tech liners King 2.5 with adjusters TE37X progressive SPC upper controls arms MOOG lower control arms Deaver J66 leaf springs Bakflip RevolverX Alpine ILX 107 JL Audio 600/1 Jl Audio 300/4 JL Audio 13TW5 Focal Components front and rear
    Anyone know what 16x7 +39 te37 look like on a double cab? Can't find it on google
  5. Feb 20, 2016 at 10:07 AM
    #285
    RjP519
    RjP519 Member
    Robert
    15 Silver Tacoma TRD Sport Prerunner LB
    OK so I was about to ask about tire fitment on a 7.5 inch wide vs a 7 inch wide wheel. I changed out the 17x7.5 4Runner
    Sport rim for the what I read was the 17x7 inch TRD Pro rim from the FJ that has been everywhere for sale. And I do understand this is TacomaWorld and that is not a Tacoma. But given that info, does the tire sit taller if the rim is narrower? The documents with the rims clearly read 17x7 and since they are mounted, I did not check the measurements.IMG_1485.jpg IMG_1505.jpg
    Kolter45 likes this.
  6. Feb 23, 2016 at 10:22 PM
    #286
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    Searching threads but can't find any spec info on these bads boys for the 3rd
    Gens.... anyone?
  7. Mar 11, 2016 at 6:01 AM
    #287
    Zerocool0295
    Zerocool0295 Member
    Mesa, AZ
    2016 TRD OR 4X4 Magnetic Grey
    Nothing yet
    Same here
  8. Mar 13, 2016 at 2:47 PM
    #288
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    I also am searching for this info so I can order new wheels (bore size, offset, backspacing)
  9. Mar 13, 2016 at 2:56 PM
    #289
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    No
  10. Mar 13, 2016 at 3:02 PM
    #290
    BrettBretterson
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    17x7.5, pretty sure +30
  11. Mar 13, 2016 at 3:31 PM
    #291
    mrproduxn
    steve
    Retired DoD SE VA
    So I want to go wider and taller. From 265/65-17 stock to 275 or 285 on a 8.5" or 9" width. I see we cannot have any deeper backspacing because can barely squeeze a fat finger between control arm and inside of tire. Am I understanding correctly that a plus 30 offset on a 7.5 rim equals roughly 5" backspacing. I have no concern with wheel protruding outward an extra inch. That will just limit my height ratio for outer wheel corner clearance.
  12. Mar 13, 2016 at 3:47 PM
    #292
    BrettBretterson
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    More like 5.5"
  13. Mar 13, 2016 at 4:30 PM
    #293
    mrproduxn
    steve
    Retired DoD SE VA
    Where am I making a mistake. Its a 7.5" rim. Half of that is 3.75". 30 mm offset is 1.18". Don't you add those together for backspacing. If the mount face is +30 mm off center wouldn't you add that to 1/2 the rim width. I really don't know but that makes mathematical sense.
  14. Mar 13, 2016 at 5:27 PM
    #294
    BORNWILDGUY
    Rich
    Florida
  15. Mar 13, 2016 at 5:51 PM
    #295
    mrproduxn
    steve
    Retired DoD SE VA
    got it thanks
  16. Mar 17, 2016 at 6:29 PM
    #296
    acidchylde
    acidchylde Well-Known Member
    Fort Collins, CO
    07 Sport AC, black, still pretty much stock
    Your mistake is that backspacing is measured from rim face, while the width spec is given for mount surface. The difference between rim face and mount surface is the lip of the rim aka flange. See the last diagram on this page: https://www.rsracing.com/TechWheel.aspx For instance the OR wheel is a 7" wide rim, but if you lay it flat on the ground and measure the height, it's 8". There's roughly half an inch in each flange. I'd say it was the same for the Sport wheel, but I never actually measured it because I sold mine with the stock tires still on them. :)
  17. Mar 28, 2016 at 9:39 PM
    #297
    fonzy
    fonzy Well-Known Member
    Fonzy
    Madera, CA
    2016 Tacoma SR5 4x4
    None
    Is our hub bore 106 or 108 mm?
  18. Mar 29, 2016 at 1:14 PM
    #298
    mrproduxn
    steve
    Retired DoD SE VA
  19. Mar 29, 2016 at 4:23 PM
    #299
    fonzy
    Fonzy
    Madera, CA
    2016 Tacoma SR5 4x4
    None
    thank you
  20. Apr 17, 2016 at 10:24 AM
    #300
    Bimercatracho
    Bimercatracho Yota noob,bimer sensai.
    It's Mr bimer,you TRD Hore.
    Screwston texas
    2008 red TRD tacoma
    315x12.50×17 pro comp A/T tires,2 " spacer. 3"lift.
    Great Post,any 17x10.
