Wheel Specs
Discussion in 'Wheels & Tires' started by replica9000, Mar 18, 2009.
  1. Nov 3, 2019 at 3:07 PM
    #481
    cactushead
    cactushead Well-Known Member
    San Diego
    2017 MGM DCSB 4x4 TRDOR
    Front hitch, 5100's, 885's, Snugtop XV, Slimline II, Sumos, bed platform, AAL, interior LED lights in cab and bed, exterior camp/backup LED's, Rigid DOT Fogs and D2 Pro Spots, Mega Ultra +130 bulbs, heavy-duty fog light, spot light, and low beam wiring harness, Weathertech mats, Re-routed dif breather and A/C drip line, dash cam, front and side cameras, anytime rear camera and nav, Blue Seas fused bus bars to cab and bed, heavy-duty bus bar w/Anderson quick disconnects under the hood for powering winch, solar, air compressor, and other accessories.
    I haven't seen anybody on this thread mention Hubcaphaven.com for spec information on OEM wheel/rims. They have a pretty comprehensive list of Tacoma wheels. You can also do a search for just about any other make or model of vehicles. Here's what they have for the 3rd gen. Off Road:
    ALY75189 Toyota Tacoma Wheel Charcoal Machined #4261104160
    Make/Model/Year:
    Toyota Tacoma 2016-2019
    Product Specifications:
    Product ID: ALY75189
    Product: Wheel/Rim (Single)
    Material: Aluminum
    Style: 6 Spoke
    Finish: Charcoal Machined
    Lugs: 6
    Bolt Pattern: 5.5 Inch
    Offset: 25mm
    OE Part Number: 42611-04160
    CoolieTaco likes this.
  2. Nov 9, 2019 at 8:43 PM
    #482
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
  3. Nov 20, 2019 at 4:29 PM
    #483
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
  4. Dec 8, 2019 at 2:19 PM
    #484
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    I tried using that site linked earlier in the thread, but it seems to have some bad info. Anybody know if our 6-lug wheels are compatible across generations or did the specs change? I have a 1st gen 6 lug and am trying to figure out what all fits it.
  5. Dec 27, 2019 at 3:15 PM
    #485
    PuyallupJon
    PuyallupJon 2020 AG Pro
    Jon
    Puyallup, WA
    2020 Tacoma
    If you put a 1.25" Spidertrax wheel spacer on a Toyota Wheel that is +10 what does that calculate out to be?
  6. Dec 29, 2019 at 9:02 PM
    #486
    Duffman76
    Duffman76 Member
    -21.75. Just convert the 1.25” to mm and subtract 10
  7. Dec 29, 2019 at 9:27 PM
    #487
    PuyallupJon
    Jon
    Puyallup, WA
    2020 Tacoma
    dang. Ok. Thanks. I wish Toyota would make an OEM wheel that is -12.
  8. Dec 29, 2019 at 9:55 PM
    #488
    Duffman76
    Duffman76 Member
    SCS does. But you have to wait for those to be in stock. Unfortunately that’s the situation I’m in right now...
    Kolter45 likes this.
  9. Jan 1, 2020 at 5:04 AM
    #489
    david08048
    david08048 Member
    Lumberton, NJ
    2012 super white double-cab Prerunner, V6
    Fuel Beast 18x9, -12 offset 265/60 Nitto Terra Grappler G2 No mud flaps Stock suspension
    I have Fuel Beast wheels. 265/60/18 -12. Made a huge difference in appearance.
  10. Jan 1, 2020 at 12:13 PM
    #490
    ODSC1
    ODSC1 Well-Known Member
    London ON
    2017 DCSB Sport MT
    I don't see the 3rd Gen Pro Wheels in the first post. I think they would be a good addition. They are 16x7 and +13
    BC Hunter likes this.
  11. Jan 1, 2020 at 12:24 PM
    #491
    ODSC1
    London ON
    2017 DCSB Sport MT
    Are all 3rd Gen spare tire rims the same/ universal? Or are they specific to the model? For example the spare on my Sport will have a 17x7.5 +30 rim and the spare on a Pro will have a 16x7 +13 rim? I've switched to Pro rims and went up a tire size and would like to have the same size tire on a steel rim for a spare.
  12. Jan 6, 2020 at 9:05 AM
    #492
    Texas
    Texas Well-Known Member
    Every Tacoma, regardless of the tire size hitting the ground will get the hankook (P245/75/16) 16" spare, EXCEPT the Tacomas that have the (265/70/16) 16" Goodyear which in that case the same tire will be on the spare rim.
    This change started last year because it was not always this way.
  13. Jan 7, 2020 at 11:24 AM
    #493
    prplefrutlup
    prplefrutlup Well-Known Member
    Corbin
    San Mateo, CA
    2020 Super White TRD OR DCSB
    got a picture that shows the truck head on to see how the tires stick out?
  14. Feb 1, 2020 at 11:11 PM
    #494
    advrider269
    advrider269 Member
    john
    Coeurd'lane,Idaho
    07' DCSB TRD 4x4
    NONE..Small lift in near future
    What Tacoma/Fj/4run alloy OEM wheels are the lightest? Anyone know? I'm reading through this complete thread...not done yet. I have 00" SR5/TRD 4x4, want to replace the original 15" alloys with a late model rim 16/17" but ...only if I can confirm the set-up will be same weight or lighter (preferred) .
    TIA
  15. Feb 2, 2020 at 1:22 PM
    #495
    Sloanmonster
    Sloanmonster Active Member
    Bill
    Palm Bay
    04 Dbl Cab 4x4
    3" lift - Billies, OME rear leafs
    OK, I'm thinking I have this right but want to make sure:
    If I'm going from this first gen TRD wheel on my Taco
    5 spoke 'Star' TRD alloys 16x7 4.5" backspacing, 15mm offset
    Part Number:
    69395
    TWTP15UN5992Z
    426110C020
    4261135170
    To 2nd Gen TRD alloy
    TRD Off-Road Wheels: 16x7, +32 mm offset, 5.25" backspacing, 6x5.5" bolt pattern
    Part Number:
    69461
    42611AD030
    42611AD031
    To have the wheel/tire be in the same exact position (with the 2nd gen wheel on the "04 Taco) I would need a .75" spacer. correct?
    15mm offset vs 32mm offset/ 4.5" backspacing vs 5.25" backspacing.
  16. Feb 3, 2020 at 9:05 AM
    #496
    Texas
    What are these original 15" alloys? I don't think the 2nd gen or 3rd gen ever got 15" OEM alloys (just steel).
    If you meant steel 15" then your only other OEM option is the 18" Xrunner wheel as it is the only other wheel with the same hub hole size.
  17. Mar 10, 2020 at 1:05 PM
    #497
    Rottencotton
    Rottencotton Well-Known Member
    Stinkin Rincon
    Superwhite 2019 Tacoma SR 4x4
  18. Mar 10, 2020 at 4:11 PM
    #498
    Texas
  19. Mar 10, 2020 at 4:41 PM
    #499
    Rottencotton
    Stinkin Rincon
    Thanks. So does this mean they won't work on a Taco?
  20. Mar 10, 2020 at 9:27 PM
    #500
    PuyallupJon
    Jon
    Puyallup, WA
    2020 Tacoma
