Wheel Specs
Discussion in 'Wheels & Tires' started by replica9000, Mar 18, 2009.
  1. Dec 15, 2009 at 7:20 PM
    #41
    ikataco
    ikataco Well-Known Member
    06 DC Sport
    How about adding 2006-2009 Toyota 4Runner 18" Limited rims?
    Specs;
    18 x 7.5"
    6 x 5.5 PCD
    +25mm offset
    5" backspacing
    weight 27.5lbs, rim only, no center cap, no wheel weights, no valve stem
    Toyota part# 42611-35290
    Weighed on a digital bathroom scale. rims are brand new.
  2. Dec 16, 2009 at 7:31 PM
    #42
    ikataco
    06 DC Sport
    TRD Sport rims
    17 x 7.5"
    +30mm offset
    5.5 backspacing
    6 x 139.7 PCD
    25.5 lbs. rim only, no center cap, weights, valve stem
    Steel spare from TRD Sport
    17 x 7.5"
    30 lbs.
  3. Dec 22, 2009 at 5:59 PM
    #43
    huninator
    huninator New Member
    Utah
    03 TRD SR5
    Rear DiffLock Grey Wire mod, K&N, 1" leveling kit
    Can someone post all the specs for the 1st gen tacoma like the first post had?
    Thanks
  4. Dec 23, 2009 at 5:27 AM
    #44
    DdayIsNear
    DdayIsNear Well-Known Member
    Crazy
    NW Jersey
    TRD Offroad
    All pro sliders
    so, thanks for the info, but i have a few questions..i dont know what all the information means...what does offset and pcd and backspacing mean? and backspacing and pcd are measured in what type of unit..
    thanks again
  5. Dec 23, 2009 at 5:31 AM
    #45
    DdayIsNear
    Crazy
    NW Jersey
    TRD Offroad
    All pro sliders
    Hay Lobos and TRDZILA like this.
  6. Dec 28, 2009 at 8:17 PM
    #46
    MIKE88
    MIKE88 New Member
    MIKE
    Massachusetts
    09 Tacoma 4x4 SR5 V6
    Does anybody know what are good 16x7 alloy wheels that are the exact same size as the 16" steel ones on a 4x4 sr5?
  7. Jan 8, 2010 at 6:02 PM
    #47
    RSH904
    RSH904 Well-Known Member
    Akron, Oh
    Red and Black Attack
    Extang Trifecta Tonneau Painted Stock Wheels De Badged Yellow Fogs AVS Bugflector II UWS Running Boads Hunter Bully Bar HD Satoshi
    Hey Help guys. I have a 2007 Access Cab 4x4. Standard Steelies with the Dunlop 245/75/R16. I have already brought home a set a of Cragers that could not clear my calipers. I want to get a AM 16 inch wheel. What Specs do I need on offset and backspacing??? Thanks for the help......
  8. Jan 26, 2010 at 11:38 PM
    #48
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    wait trd sport wheels hub bore is 108mm? does that mean our hub diameter isnt 106mm but 108mm????
  9. Feb 13, 2010 at 5:39 AM
    #49
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Does anyone know the backspace on the stock 5 lug 15in wheel?
  10. Mar 7, 2010 at 6:08 PM
    #50
    Roadman
    Roadman Member
    Bob
    Northern NH
    V6 manual
    Non yet ;o)
    Thanks for posting that link. I'm a new to me Taco owner. Need season specfic tires. So looking for another set of rims.
    BC Hunter likes this.
  11. Mar 17, 2010 at 1:58 AM
    #51
    Wolfshart79
    Wolfshart79 Active Member
    BSP 05 PreRunner SR5
    05' SR5 Prerunner:
    Bolt Pattern:6x5.50
    Offset Range:-4 to 20
    Wheel Size Range:16x7.0 to 22x9.5
    Stud_Size:12x1.5
  12. Apr 7, 2010 at 11:29 AM
    #52
    Cappy Cap
    Cappy Cap Well-Known Member
    Boston
    08 Reg. Cab
    K & N Intake, Alpine S-10 Shallow Mount Sub, Alpine CDA-9884 H/U, Alpine Type-R Components, Alpine Amp, 3.73 rear end, Welded on Muffler, Bug Deflector, Rain Guards, LCE Short Shifter,
    Anyone know the weight on the 08 tacoma reg cab 15" 5 lug wheels? this will probably define what gear ratio i get when i upgrade
    Thanks,
    Brad
  13. May 2, 2010 at 5:32 PM
    #53
    jandrews
    '09 FourDubDee TRD OR
    This thing hasn't been updated in a while, but thought I'd throw in that TRD Ivan Stewarts have 4.5" backspacing.
  14. May 5, 2010 at 2:48 AM
    #54
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    im no wheel guru here...so im guessing its best to keep our offset positive when picking out some aftermarket wheels? and keep it hub centric of course?
  15. Jun 20, 2010 at 10:13 PM
    #55
    J0HN_R1
    J0HN_R1 Well-Known Member
    Calgary, Alberta
    2014 Tacoma TRD Sport DCSB
    Bilstein 5100's @ 2.75" FR, Deaver 1.5" TSB leafs RR, SpiderTrax 1" spacers, custom LED interior & bed lights, 2005 4Runner Sport 17" wheels powder coated satin black
    Thank you...
  16. Jun 26, 2010 at 1:26 AM
    #56
    T3VB
    T3VB Member
    does anyone know if Mikey Thompson SideBiter Wheels will fit on a Base Model 5 Lug? I will be running a 31x10.50 and wanted to make sure the offset and backspace will not be too outta whack.
    SideBiter Specs - 15x8 / Backspace: 3.31 Inches / Offset: -30mm
    I dont want the tires to stick out a whole bunch. I want them to look aggressive but not like a Sport Quad or something.
    HELP!
    *Edit- Yes I have a lift.
  17. Jul 2, 2010 at 5:16 AM
    #57
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    are the weights mentioned in the first post just the wheel or wheel and tire? cause if its just the wheel i can weigh the stock 5-lug wheel.
  18. Jul 2, 2010 at 5:51 AM
    #58
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    I did buy a set of aftermarket wheels and tires for my 09 2WD AC.
    The wheels are 17X7 5-114.3 38mm offset
    The tires are 235/55R-17
    I have had no clearance issues with the tires. The final diameter of the tire and wheel is very close to stock so the speedometer is not an issue.
    This combo is on a street Tacoma with no illusions of going off road.
  19. Aug 13, 2010 at 9:08 PM
    #59
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  20. Aug 18, 2010 at 9:21 PM
    #60
    6spdtaco
    6spdtaco Well-Known Member
    VT
    Taco
    Does anyone have specs for the TRD Baja Wheels? This thread says they are 16x7, the dealer told me 16x8, but I think they were just guessing. How about backspacing?
